Question about Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair
Wheelchair just stops and will only turn in circle. Right hand side large wheel stops altogether then lights flash on controller. Couger 10
Posted by sue waite on
Mark Brown
    Filmmaker:
    Uploaded 5 video answers.
  • 168 Answers
Sounds like a loose wire to or on that motor or your motor brushes need to be replaced, both cheap fixes.
Posted on Dec 02, 2013
4 Related Answers
Anonymous
  • 40 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Posted on Mar 30, 2009
Anonymous
  • 32 Answers
SOURCE: jazzy wheelchair 1170....left side stops and sticks,.
those codes 1 light flashing and 2 lights flashing refer to a left and right motor fault respectively....expensive repair
Posted on Apr 03, 2009
Anonymous
  • 7 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair, it is the secondd row of ligths on the controller, the ones that indicate speed. They are flasing steadily
Check that you don't have the charger cord still connected or the motor disengaged.
Posted on Jun 01, 2010
Louis Smith
  • 104 Answers
SOURCE: pride jazzy 600 power wheelchair controller lights flash
make sure the motors are not disengaged, turn off chair, can you move it by pushing it? if so lock the wheels and try again. next is the controller in lockout. press and hold the on button till it beeps push joystick forward til it beeps pull it back til it beeps turn off try again. you can call 1-800-800-8586 for tech support
Posted on Oct 01, 2012
Jazzy lights blink six times then go off
this could be a right brake fault or a controller fault. Check and see if the right motor has been disengaged. The easiest way to chreck this is to try and push on the right side of the chair. if the wheel begins to turn then the motor has been disengaged and you should be able to re-engage the motor and stop the wheel from turning. At this point you will have to turn off the chair and turn it back on to see if the fault goes away. If that is not the problem then it could be a loose motor connection. Check all your wiring connections on the motor to the controller. The other problem it could be is a controller fault. check all the connections on the controller and the wiring. Turn it off and back on to see if the fault goes away. If the fault is still there you will probably need to contact a service tech for them to get on line with the controller and find the root cause. They should have the diagnostic tools to check this.
Aug 12, 2014 | Pride Jazzy Select 6 Indoor Power...
MPV4 - Right wheel is semi locked
Could be a number of issues here.
Caster bearings need cleaning\replacement
Fork bearings need cleaning\replacement.
Drive Tires could be too low and need air.
Motors were not properly mounted to gearbox and/or motor coupler is damaged.
Too much crud is wrapped around a wheel - obstruction.
The VSI controller isn't flashing a code so you are electrically connected to the motors, brakes and batteries. Problem appears to be mechanical - not electrical.
Feb 04, 2014 | NRS Hoveround MPV 4 - Hovaround Used...
Slightly wobblyLarge Wheel
Properly inflate tire and make sure wheel retaining nut on shaft has not come loose.
Jun 07, 2013 | Medline Travel Folding Transport Wheel...
Pulls to the right and stops and wont go and the control lights flash on and off
What are number of lights and colors? Check motor connections to controller. Is it freewheeling?
Mar 16, 2013 | Pride New Jazzy 600 Power Wheelchair by...
Red light flashing on joystick about 10 min after charging
Most of the time it may be the batteries at fault. One more thing to try is charging the chair with the Joystick on all night 10-14 hours uninterrupted charging. Your chair may suffer from current roll back. There is a circuit in your system that has to be reset by the long charge cycle to reset it. I did not make this up. it occurs when the motors over heat or have a a large current draw. the chair will operate normally for ten maybe even twenty mins. then suddenly drop down to 2 flashing red lights.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Feb 18, 2013 | NRS Hoveround MPV 5 - Used Power...
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Location of fuse to control side mirrors on 2009 97x
Fuse panel in end of fascia
No. Amp. Function
1 15 Steering wheel lock
2 5 Steering column unit; ignition switch
3 10 Hands-free; cabin CD changer; SID
4 10 Main instrument unit; manual climate control;
automatic climate control (ACC)
5 7.5 Control module in front doors; Park Brake Shift Lock
(automatic transmission)
6 7.5 Brake light switch
7 20 Fascia fuse panel; fuel filler door
8 30 Control module in passenger front door
9 10 Fascia fuse panel
10 30 Trailer socket; electrical socket in storage compartment
between seats
11 15 Data link connection (diagnostics)
12 15 Interior lighting incl. glove compartment
13 30 Accessories
14 20 Radio, sound system I; control panel,
Infotainment System
15 30 Control module in driver's door
16 - -
17 - -
18 7.5 Manual climate control; fan
19 - -
20 7.5 Headlight levelling switch
21 7.5 Hands-free; brake light switch; manual climate
control; clutch pedal switch
22 30 Cigarette lighter
23 40 Cabin fan
24 7.5 Airbag control module
25 - -
26 5 Yaw sensor (cars with ESP)
27 - -
Trunk fuse panel, left-hand side
No. Amp. Function
1-5 MAXI -
6 30 Control module in left rear door
7 30 Control module in right rear door
8 20 Trailer
9 - -
10 30 Left-hand brake light; rear right turn signal; right tail
light; right reversing light; high-mounted brake light;
trailer lights
11 - -
12 - -
13 - -
14 - -
15 15 Seat heating, left seat
16 15 Seat heating, right seat
17 7.5 Autodimming rearview mirror; rain sensor; tire
pressure monitoring
18 15 Sunroof
19 7.5 Telematics (OnStar)
20 7.5 DVD player (navigation system)
21 7.5 Saab Parking Assistance (SPA); control module in
rear doors
22 30 Amplifier, sound system III
23 - -
24 10 Movement sensor; CD changer in trunk (accessory)
25 30 Electrically adjustable driver's seat with memory
26 30 Right-hand stop light; rear left turn signal; left tail
light; rear fog light; left reversing light; license plate
lighting; trunk lighting; trailer lights
27 - -
28 - -
29 - -
Fuse panel in front of battery
No. Amp. Function
1 60
MAXI
Secondary air injection pump (certain models)
2 20 Fuel pump; preheated oxygen sensors (lambda
probe)
3 10 A/C compressor
4 30 Main relay
Relays
1 Secondary air injection pump
2 A/C-compressor
3 Preheated oxygen sensors (lambda probe)
4 Main relay, engine (ECM/EVAP/injectors)
Sep 13, 2012 | 2006 Saab 9-7X
Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Apr 30, 2010 | Pride Jazzy Select 6 Indoor Power...
How to use cruies controw on a 1997 isuzu rodeo
First-on dashboard right hand side of steering wheel there are large (approx 1" sq) buttons-push to turn on-push again to turn off-for the rearwindow defroster,hazard flashing lights and....cruise control. Push cruise button to "on" and you'll see green lights on speedometer bezel light up. On end of wiper control stick on rightside of steering wheel-you'll find a pushbutton. Get car to speed you want-then push this button in. To turn off cruise control completely-push first button you pushed on dashboard.
Mar 21, 2010 | 1997 Isuzu Rodeo
Jazzy wheelchair 1170....left side stops and sticks,.
Change out the motor brushing on the motor that is not working, or get a nail filer & rub it against the metal pins the back of the chair for a better connection
Nov 30, 2008 | Pride Mobility Products Jazzy 1170 XL Plus
Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair Logo
89 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
