Question about J4constructioncom La Toscana Elba Thermostatic Shower Valve, Brushed Nickel AL113828
My ELBA portable air-conditioner EPAC A4010D(WH) got an E1 error although I clean all the filter but still cannot work...
Posted by Kingsley Jin on
Comfort Control Center 2. Why is E-1 error displayed?
[PDF]Customer assistance for air filters cleaning (E1 code)
www.sharpusa.com/.../air_man_AFS100FX_S120FX_S125F...
Sharp SolarCustomer assistance for air filters cleaning (E1 code) on Sharp Air Conditioners. The display will indicate an E1 code and not allow the unit to operate until the ...
Sep 08, 2015 | Dometic Rooftop RV Air Conditioner
What does E1 mean on portable AC
E1 "Error Code" means different things with different appliances and you need to give a specific Make and Model of AC..
It should be explained in the troubshooting section of the user's handbook..
"Clean Filter" is a common routine message..
Oct 19, 2014 | Heating & Cooling
Keep getting code e1
According to page 24 of your owner's manual, the E1 error is indicative of a short circuit in the Indoor Air Thermistor. The unit will likely require service.
Good luck,
Marty
Jun 21, 2014 | LG Electronics LP0910WNR Portable Air...
What to do to fix the E1 error on a haier her08xc7
Push buttons about five times each beforjust to make sure they are not stuck....then......Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter. See the Care and Cleaning section in your use and care manual. After cleaning, replace the filter and plug the air conditioner back in.
Other forums say the E1 code is because the AC thinks a button is stuck or because it's dirty, but almost all of them say to use the remote and it'll work ok.
Jul 23, 2012 | Haier HWR08XC7 Air Conditioner
E1 error code
E1-Automatic filter clean reminder.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 07, 2011 | Haier HWR06XC7 Air Conditioner
I have an E1 error code
Hi
E1 means Automatic filter clean reminder. Turn the air conditioner OFF and unplug it. Kindly make sure that the air conditioner is unplugged for the automatic filter clean timer to reset, then clean the filter. After cleaning, replace the filter and plug the air conditioner back in.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | GE Heating & Cooling
Have a E1 error on our Danby Air Conditioner
E1 error on Danby is to clean or replace air filter. Check that filter is properly installed as that may also cause the error.
Jul 31, 2008 | Danby DPAC8020 Air Conditioner
Air conditioner has to be reset --E1
If your a/c unit is portable,and E1 code most always is "air filter cleaning time" or" water level to high ".
To reset air filter interval turn unit off at power switch then unplug.Hold power switch down while plugging in....unit will go through a short self check then beep.Release power button after beep.Unit should now be reset.
To reset water level....just drain some.....not all.
Most portables use water for increase cooling......so leave some in.
Jul 27, 2008 | Sharp AF-S100FX Air Conditioner
J4constructioncom La Toscana Elba Thermostatic Shower Valve, Brushed Nickel AL113828 Logo
115 people viewed this question
Top J4constructioncom Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
Are you a J4constructioncom Heating and Cooling Expert? Answer questions, earn points and help others
