Question about Sharp AR-407 Copier
My AR-1516 is showing H5 on the screen,how do I fix it?
5 Related Answers
Everett Lin
  • 990 Answers
SOURCE: error code h5-01
Hello sir; the paper exit sensor get stock, just put back in the track let it moved free.
Posted on Apr 14, 2009
Anonymous
  • 62 Answers
SOURCE: sharp ar-m350u error code h5-01. How do I fix
vheck this link out http://www.fixya.com/support/t1570580-remove_h5_01_error_code_sharp_arm550n
Posted on Apr 15, 2009
MIAN
  • 87 Answers
SOURCE: error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
Posted on May 09, 2009
Anonymous
  • 63 Answers
SOURCE: H5-01 code
First thing H5 means you've had 5 continues jams at or before your fuser unit. So the first thing you need to do is make sure you all your paper out of the machine and double check the fuser unit for paper as well as the transfer belt unit for paper on it or behind it. You can simply remove it by first removing your fuser unit (lock is under fuser, a turn dial) then pull the transfer belt out and tilt up. **** Warning**** use caution when removing belt as to not damage the unit. After you do all this you will need to reset the code.
Press the buttons in the following order :
#/P key (program) - Asterisk (*) key -CLEAR key -
Asterisk (*) key - Ready for input of a main code of simulation
Type 14 with the key pad then press your copy key
Press execute then YES Once done press the CA key on the panel and the machine will restart.
Posted on Oct 12, 2009
Anonymous
  • 146 Answers
SOURCE: AR M700N copier jams... trouble code H5-01
h5-01 error is five consecutive jams in the fusingg section. P*C* gets you into dervice mode thenn 14 for trouble reset. then execute and restart. check the fuser pawls for dull edges and breaks. also check roller tensioning system on fuser.
Posted on Oct 13, 2009
Show in the screen (H5-02) Please tell me what the problem
It seems there is a paper jam in the fuser unit. Remove this ,OFF and ON machine.
Feb 22, 2011 | Sharp AR-507 Copier
Code H5-01 on Sharp AR-M450N. Cleared jam. How do we reset? Thanks
H5-01 is repeated jamming in the fuser unit, please check you have removed all paper from the heat section. press P/# * C * then 14 and copy start and follow the instructions on screen to reset.
Oct 14, 2010 | Sharp AR-M455N Copier
H5 flashing on the display, anyone tell me what the error is please? It's a Sharp AR-161 copier
H5 doesn't show up on the service code manual. However, all error codes beginning with 'H' are related to the fuser, this is the heating portion of the machine. Be careful if it still prints despite the error code, you may damage the unit. It should be looked at by a service rep.
Jan 12, 2010 | Sharp AR-161 Laser Printer
Oct 13, 2009 | Sharp AR-M700N Copier
Error code H5-01
HI.H5-01
check its cable
reset this code
press ,p,*,clear,*
May 07, 2009 | Sharp AR-M350U Copier
Code H5-01 indicated from the screen
H5-01 Exit sensor problem try to reset with simulation mode Press "Program" Press "Interrrupt: Press "Clear" Press "Interrupt" enter 1 & 4 then Press "Start"
Jul 12, 2008 | Sharp AR-407 Copier
Sharp AR 250 with error code H5-01
SHARP AR250 H5-01 Papersensordefective in the fusing unit
Normally you can clean the build up of toner off the sensor, and it'll sort itself out. It also could happen by having 5 paperjams in a row.
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Feb 25, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-407 Copier Logo
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
