Question about Epson Stylus C84 InkJet Printer
All lights blinking - what do they mean?
All lights are on and blinking in my Epson CX-2900 after a power-on!
  • Anonymous Apr 28, 2009
    Though I haven't checked the cartridges if they are faulty or not as you suspected, the info you gave me is very much helpful... Thanks, danielgordon!
Anonymous
    Scholar:
  • 84 Answers
1. The printer cartridges are either absent or bad and should replaced. 2. The cartridge housing is stuck at its parking end. 3. The cartride housing is faulty and should be replaced. Good luck
Posted on Apr 27, 2009
My epson 1410 blinks 2 red light whwn i turn it on. Please help
If power button is on (not blinks) and two red lights are blinking alternatively it means the inkpads are end of life. Ask epson service centre to reset it and replace the ink pad. You can go for wic reset with fees.
If power button is blinking with two red lights, it means your printer cannot initialize. Its a fatal error. Ask epson service engineer to service it.
Oct 27, 2016 | Epson Stylus Photo 1410 Printer
Epson 460 powerlite hooked to smartboard green light blinking and no image.
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Dec 06, 2012 | Epson PowerLite 410W LCD Projector
My Epson CX-4100 printer/scanner shows error "E" in the LED display for "Copy". All other lights blinking as well. Never had this problem.
Turn off the Printer and Unplug it from the Power Supply.
Remove the Cartridges from the Printer!!!!!
On the Backside of the Cartridge you would see a Copper Stripe, Wipe the Copper Stripe using a Paper Towel!
Reinsert the Cartridges and Restart the Printer.
Good Luck!!!
Mar 21, 2011 | Epson Stylus CX4100 All-In-One InkJet...
All leds are blinking continously in Epson stylus cx 5500 printe
turn on/off, unplug, plug in2_bing.gif, should reset configs.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Is the vista window not support the cx 2900?
Check the ERpson support site to see if they have a vista driver. it is possible they dont and you may need to sell off your old prinhter and upgrade
Aug 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Power and error botton blinking epson cx 2900
Could be ink cartridge no contact, or it is dirty. Or if you try to print and this printer that flag a message " end of service life......parts." . You should reset it counter using third party software. In kinda connection with ink pad.
Apr 18, 2009 | Epson Office Equipment & Supplies
Having difficulty on printing documents by using epson cx2900?
Have you changed the ink cartrage? Could simply be out of ink.
Check your last printed item. See if it is getting lighter toward the end of the document.
Feb 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Cartridge holder does not move to
Hi
have you tried pressing it down for 3 seconds? on the printer utility on your computeris there an option to change cartridge? pls check that, if all fails then that's a hardware issue. call epson for replacement.
Hope this help
Dec 20, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus CX4600
If all of the lights on the control panel are flashing and you see the letter E in the Copy window, the print head may not be able to move back and forth freely. Follow these steps:
  1. Turn off the Stylus CX.
  2. Open the scanner.
  3. Remove any jammed paper or other obstructions from the paper path.
  4. Carefully lower the scanner.
  5. Turn the Stylus CX back on.
alert_note.gif Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Stylus CX.
And the last thing you could do, is to check if the rod where your carriage slide is dry...if so put a little bit of oil on it
Apr 03, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus C84 InkJet Printer Logo
229 people viewed this question
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
