Samsung fridge freezer problem
samsung fridge freezer diy help
Move the fridge a bit futher from teh wall , to increase aireation.
Also clean dust on the coils at the back.
If that does not work, then there is something wrong with the freezer evap system.
Heating coil and thermostate in the defrost system must be tested to find out.
Cant bring up anything on the # u provided
Some refrigerators run the defrost themostate...
IF d. thermostate bad of some frigs fan motor will not run ..
check thermostate for continuity . frig has to be at 20 to 30 degrees to check.. got to be certain temp to close themostate
can cut wires and splice to ..by pass thermostat to check
