FUJIFILM FinePix S1600 Digital Camera Logo
Question about FUJIFILM FinePix S1600 Digital Camera
No display is seen. only black lcd.i dont know is it wrong with setting or what. if i click the pics, no image again black images .guys plzz help me with this problem
Posted by sanam maharjan on
Gavin Jessel
    New Friend:
    Problem Solver:
  • 13 Answers
Ask Fujifilm.
Posted on Oct 25, 2013
1 Related Answer
Anonymous
SOURCE: I dont know how to
You have to take the camera out of silent mode for the flash to work. It is a very annoying inconvenience. Then if you put it in silent mode, the flash won't work. And trying to find a phone number so you can call and speak to an English speaking fujifilm rep is about as easy as finding a cure for cancer. This is definitely my last fujifilm product.
Posted on Apr 30, 2013
SONY VAIO PCG-61813M
I have the same problem, It works at an external display and the lcd and lcd cable work on another laptop.
The problem is that i have a sony vaio and it has no inverter, or at least i dont see one like an hp laptop for example. i tried to switch image from external monitor to lcd and it doesnt work. i tried everything. dont know what to do more, Hope you can help.
I have a Sony Vaio pcg-61813M.
Thanks.
2answers
2407 screen goes black
faulty connector... need to call a repair guy to solder a connection.. usually 50 bucks
What is wrong with my camera?
The display being black can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
2answers
HI I HAVE APANASONIC DMC-TZ15 CAMERA..... I HAVE AWHITE SCREEN WITH ALL THE MENU WORKING BUT I CANT SEE PICTURES OR TO SEE WHAT I M SHOOTING... IV REPLACED THE LCD BUT THE PROBLEM WOULDNT...
This is because your problem isnt the LCD screen viewer; if you take pics and transfer at pc... the same condition appears when you transfer this pics at PC ?
If yes, and the problem continue, could be the CCD image sensor go to bad; in both cases this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Sony service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps
I have a Nikon D3000 digital camera. When I turn it on the info menu is displayed on the monitor and I cannot see the image that I am shooting. When I turn the info menu off it turns black and says...
That is the factory setting. If had seen the image on the LCD before taking the picture, then there was something seriously wrong with the camera. The D3000 works as SLRs have worked for over half a century, providing you with a viewfinder to compose your photos.
2helpful
Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open,...
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open, but no image is available just a black screen. When I I try to take pic is showed very low light but doen't show image of pic taken when I check. Please advise. This a brand new camera and was taken excellent pic as of this friday. [email protected] Mr.Tracy Johnson
2helpful
2answers
LCD has gone blank
Hi this is tech crazy
Based on the information you have provided, it appears that you may have
encountered this issue. To determine if the CCD (image sensor) is
working properly, please follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
four.
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service
Hope this solution helps you a lot
Please rate me on the above said solution
3answers
Rca scenium 52 inch replacement screen
I`ll have to be the bearer of bad news, the image is not burned onto the screen it is burned into all 3 of your picture tubes, which basically means the set is junk because the cost is too high.
Nokia N70 trouble with galary after saving pictures
you do one thing , you select image from your PC ..right click on it & go to its properties,uncheck read only & hidden option & then trfr this image to your h.set .most probably you will be able to trfr that pic to other phone.If you are successfull in doing so ,then you need to trfr all images again in the same manner .
sometimes if you have hidden any image in PC or have clicked read only.then after trfrng that image in your h.set you are not able send them to other phones.
Top FUJIFILM Cameras Experts
Steve
David Shaub
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
