Eclipse CD3422 CD Player Logo
A
Anonymous Posted on Oct 25, 2013
Info 3 is displayed when a cd is inserted - Eclipse CD3422 CD Player
1helpful
Will not burn a CD
Have you checked which CDR media the device can use.
This may be as simple as using a CD-R rather than a CD+R or vice versa,
Also check if you may be burning to a CDRW or CDR.
Hi, I have a NAD C541i cd player when i turn it on i get three blue line on the display, i open the draw and insert a CD disc but the blue lines stay on the display and the disc don't play. can you...
The blue lines you mention should flash when trying to find
the 'Table of Contents' of your CD, even if a CD isn't loaded.
If when a CD is loaded and these lines flash for a while without
any CD info e.g track no. / disc length then it's more likely that a problem has occurred with the laser.
Various NAD CD players use the Sony KSS-213 Laser unit
and for some reason particularly with NAD CD players, they tend
to drift out of calibration over time so what i usually do when i come across this is very finely adjust the pot trim on the laser itself and testing a CD between adjustments.
I insert cd but displayed disk error
1. Get your user guide ready,
2. Check the type of CD you insert,
3. Make sure your player is compatible with this particular media type (info should be in technical specifications table somewhere at the end of the manual)
4. If it does, make sure the dics is clean and scratch-free.
5. Make sure the format of media is supported by your device. Some players support VCD, SVCD, DVD etc. but do not support plain data CD which might be the reason of your disk error.
Need a password
Dear i have send some instruction of need a password.
please follow the instructions.
and you receive a password.
Thanks.
1. Download a free demo version of Windows Key (to reset a "Demo12345" password for a trial) or buy an instant download online (to reset an unknown password)
2. Run the downloaded file to install Windows Key. You can install Windows Key on any PC you have access to
3. At the end of the installation process enable the "Run Windows Key" check-box and click the "Finish" button. Windows Key will be launched automatically
4. Create a password reset CD, USB Flash drive or a driver floppy following the instructions below:
Using a Windows Key bootable CD 1. Click the "CD image" link
2. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. The file is usually located in the 'I386' folder of the Windows Setup CD. Click "Next" (Don't have any Windows Setup CD? Request a Windows Key .ISO download)
3. Enter you name and set your own password for the bootable CD (you may set an empty password). Click "Next"
4. WindowsKey.iso file is created
5. Insert a blank CD, specify your burning drive from the list and click "Next"
6. Windows Key password reset CD is ready
What should I do next?
7. Reboot your system with this CD
8. Windows Setup process starts
9. After all the required files are loaded from the bootable CD, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable CD
Continue to step 14*
Using a Windows Key bootable USB Flash Drive 1. Click the "USB Flash Drive" link
2. Connect a blank USB Flash Drive. Click "Next"
3. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. Click "Next" (Don't have any Windows Setup CD? Request { /iso-request.htm } a Windows Key .ISO download)
4. Enter you name and set your own password for the bootable USB Flash Drive (you may set an empty password). Click "Next"
5. Windows Key password reset USB Drive is ready
6. Reboot your system with this USB Drive. To reboot your PC with USB Flash Drive you may need to set the following options for the BIOS Setup Utility: after rebooting your PC please press "Del" or "F2" to run BIOS Setup Utility, go to the "Boot" section and press "F6" to move the "Hard Drive" device up, press "Enter" on the "Hard Drive" option and press "F6" to move the "USB Drive" device up. After all the changes are set please press "F10" to exit and save the settings
7. Windows Setup process starts
8. After all the required files are loaded from the USB Drive, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable USB Flash Drive
Using a Windows Key driver floppy 1. Click the "driver floppy" link
2. Insert a blank floppy into the floppy drive and click "Next"
3. Enter you name and set your own password for the driver floppy (you may set an empty password). Click "Next"
4. Windows Key creates three files on the floppy: winkey.sys, winkey.inf and textsetup.oem. The driver floppy is ready What should I do next?
5. Insert Windows Setup CD or bootable floppy and reboot your PC
6. Windows Setup blue screen appears
7. Press "F6" when Windows Setup prompts for additional drivers at the bottom line of the blue screen
8. Windows Setup continues loading required files from the bootable CD or floppies
9. Windows Setup prompts you to press "S" to specify additional drivers. Press "S" and insert the Windows Key driver floppy
10. Press "Enter" to specify the "Windows Key" driver
11. Windows Setup loads the files from the floppy drive
12. Windows Setup continues loading the files from the Setup CD or prompts you to continue with the rest of the bootable floppies
13. After all the required files are loaded from the Setup CD or bootable floppies, Windows Key starts working. It displays your license info and asks to enter the password that you set for the driver floppy
Boot Mode 14. Please enter the password that you have set for the Windows Key bootable media
15. Select the Windows installation to be unlocked
16. Windows Key asks: "Undo Windows Key changes? (Y/N)". Press "N" if you want to reset the password or "Y" if you want to leave the original passwords and cancel the program changes
17. Select the account to reset the password for
18. Windows Key asks: "Reset 'account_name' password? (Y/N)". Press "Y" to reset the password or "N" to leave the original password
19. Windows Key asks: "Reset password for another account? (Y/N)". Press "Y" to reset password for another account or "N" to quit Windows Key
20. Remove the Windows Key bootable media and restart your PC.
2answers
My Zenith PC displays Verifying DMI pool data . Update Success
Sometimes this can be even simpler. Put in your Windows CD and boot to safe mode command prompt and type fixmbr. This will repair your master boot record for your primary boot harddisk. Eject the windows CD and reboot and see if it fixes your problem.
1helpful
Cd player does not work
While holding 1&6 pushed ,press disc 3 times .
check will be displayed on the radio screen then press & hold N° 5 for 3 sec.
Then CLR will be displayed .
Now check if your disk works!
Error
The manual states
1. " An (ERR_) message will appear, then change to a flashing (DISC), then the CD will be ejected."
You will have 5 uninterrupted attempts to insert the correct CD.
2. After the 5th incorrect attempt, the display reads (HELP)
3. If (HELP) appears on the display, press button (6), then the (FUNC) button, and hold them for 5 seconds.
4. Press the (FUNC) button. You will have 5 more attempts to insert the correct disc.
IF AFTER 10 TRIES, AND IF THE CORRECT KEY CD HAS NOT BEEN INSERTED, THE DISPLAY READS (CALL 800); THE UNIT MUST THEN BE RETURNED TO ECLIPSE TO BE RESET. CONTACT ECLIPSE DEALER OR CALL (800) 233-2216.
Can't play CD-R on my car cd player
Hi there!
1. Have you checked the manual for that?
2. Is it working before?
3. Have you tried different CDs? are they working?
Ok I had the kenwood KDC-MP235 installed and...
The front aux input is only capable of accepting audio signals and definitely won't display any track tags.
If you have an iPod, I think with the KCA-iP500 adapter it will display song info on the front as well as allow control from the Kenwood's controls.
As far as the song info on a CD - it should display if you've got a CD with CDTEXT info on it, or if you're playing an MP3/WMA CD. Most regular audio CDs won't be able to display song info.
Cd's are ok but no dvd's...
Had similar problem. Found the disk was not rotating. Adjusted the torque on the hold down screws of the drive unit allowed the disk to spin. Still had some motor noise, but DVD would load.
Top Eclipse Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
