Toshiba TN55X81 55" Rear Projection Television Logo
Posted on Sep 29, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Convergence and audio problems
TV ~14 years old. No audio and the picture for all colors is out of alignment except in center. The picture is 20% concave. All this occurred at the same time.
Vista Electronics
Level 3:
Genius:
  • Master 1,694 Answers
  • Posted on Sep 29, 2007
Vista Electronics
Master
Level 3:
Genius:
Answers
1694
Questions
Helped
585043
Points
2786
1)replace convergence IC's w/best quality. re-align as needed. 2)recheck audio,source and selections in menu. PVAT!
I have a Magnavox 51mp392h/17,that now has double vision (text is double,all images) there is also green, off red colors on the picture. Please help me the tv is 6 years old. should i throw it away or get...
No.Should cost u like $300-350 for parts and labors.Get it fixed any local tv shops can fixed this problems,very common problems for DLP CRTS tubs design projection tvs Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture colors lines R,G,B mis alignments,have pictures colors shadow or 3D pictures look alike.The tv convergence board must have it parts replace like 2 STK convergence ICS and some or all of it resistors to fixed the convergence board to solved convergence pictures problems.
The blue coloring is way off center
Tv have a problems known as a convergence problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Top and bottom of picture in center of screen dips like a bow tie
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board reqiured changes it 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board problems to solved the tv picture convergence picture problems.The shop,will cost like $300-350 for parts and labors.
1helpful
My television is only 6 years old. Red lines have appeared in the form of a wave pattern on the screen. What does this mean?
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have a colors shadows or 3D pictures look alike?Ur tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
51 Hitachi rear projection 6 years old, can't get it to focus, Has sound. Can only get the picture to come in abpout 80%. Around the perimeter, sports scores and subtitels are not readable. Used the fucus...
Flash Focus magic button no longer work.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost $300-350 for parts and labors.
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Problem with picture on wide sreen TV
You probably need to get a Sony TV Convergence Kit. More information can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
TV comes on, various colors are not aligned
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
2answers
Colors off
Set all convergence controls to center and then manually set all tubes to as close as possible to coincide with each other. Then, use those electronic potentiometers to fine tune the picture.
Ghosting - colored shadows - guns out of alignment?
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
