Question about Samsung YP Audio Players & Recorders
How do i install samsung yp 650 mp3 with no disk bought second hand and am not computer savy
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Samsung YP-K3 MP3 Player
Available from Samsung suppoort site along with firmware upgrade tool
Posted on Jul 11, 2008
Anonymous
SOURCE: samsung mp3 yp-u3j no driver
download windows media player 11
once you install it follow these steps:
-right click my computer-click properties-click on hardware tab- then click on device manager
- plug in your yp-u3jqby mp3 player
-you should see your mp3 player pop up. double click it. then upgrade drivers.
after endless hours... i finally got it to work. i guess the trick is windows media player 11.
Posted on Sep 12, 2008
Anonymous
  • 65 Answers
SOURCE: I lost the installation cd for my mp3 yp-k5
try to download the software from the manufacturer's website and install
Posted on Sep 26, 2008
Anonymous
SOURCE: Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site (http://www.everythingusb.com/forums/showthread.php?threadid=11238). To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
Posted on Nov 17, 2008
Anonymous
SOURCE: Samsung YP-K3 mp3 player requires driver but I have no cd!!
I've had this problem. Windows media player doesn't seem to find it, and I couldn't figure out which file I needed from the site. I have xp, but I'm assuming this might also work for vista. Go to Control Panel. Open System. Click the Hardware tab. Click the Device manager button. Find the yellow question mark labled Samsung YP-K3 and doubble click it. This should open a window that will let you (re)install the driver, which it will find for you after having you set up a few simple options. Hope this helps.
Posted on Aug 01, 2009
1helpful
Computer wont recognise my software for yp-u3 mp3 player
go to my computer icon on desktop !
click right mouse go to proberties --- system or device ---device management --- there you can solve the problem .
rate please !
best regards .
3answers
My mp3 wont connect to the computer
you need to go on the samsung website and go on troubleshooting problems and follow the step by step gide to sove the problem
Samsung yp-u2
The install disk is just a cd that installs windows media player in case you don't already have it. instead..just connect the mp3 player directly to the computer. Then go to my computer and drag and drop it into a new folder. But if you still just want the windows media player, then you can download it from http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx. I hope this helped you.
1helpful
2answers
U3 mp3 player
I bought a Samsung YP-U3 . It had the installation cd .When plug to usb port It's charging but it shows disconnected...the samsung media studio and my pc don't recognise it, allways ask new samsung YP-U3 found. when i give the path to cd it dint get. Please help me....
4helpful
YP-U2J - Need download - Didn't come with CD
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
CLICK Here to Download : Firmware Update
In case u have WMP 11 and player not working, this error is common after installing Windows Media Player 11
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Open Questions:
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
