Samsung SGH-i450 Cellular Phone Logo
Posted on Apr 27, 2009
I am unable to set the default theme wallpaper on the screen.. a screensaver is set and could not change it ... i have even taken the memory and tried.. i also restored the factory settings.. but none of it worked out..
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
170
Points
AFTER U INSTALL ANY THEME GO TO YOU PHONE TOOLS OPTION THEN OPEN THEMES THEN GENERAL....THERE U CAN FIND YOUR INSTALLED THEMES...
The text on my pc keeps going blue, how can I stop it?
Windows allows you to change the themes of your computer. This includes the wallpaper, the screensaver when your computer is idle, any noises it makes, and even the color of the toolbars and windows. Sometimes, however, when you restart your computer, the theme will revert back to the Windows default theme, which is called Aero. This can be because you have not disabled Aero, because your performance settings are using too much energy, or because your screen resolution is too high or low for the theme you are using.
Screen Resolution b> The higher your screen resolution, the sharper the images and text will appear. Sometimes, however, the of the wallpaper for the theme is not the same as the screen resolution. This can cause your theme to revert back to the default. To fix this, click the "Start" button. Then click "Control Panel." In the "Control Panel" window click "Adjust Screen Resolution" under "Appearance and Personalization." Select the resolution that is the same as your wallpaper. b> Performance Settings b> If your computer is running on high performance settings, your computer's energy will be used quickly and Windows may automatically change the screen saver to keep the energy from running to low. To change your performance settings, open the "Control Panel" and click "System and Security." Then click "Change Battery Settings" under "Power Options" and select "Power Saver" or "Balance." b> Disable Aero b> Aero is the default theme setting for Windows Vista and Windows 7. If you try to change your theme and it reverts back to Aero, it is because Aero is still not disabled. To disable Aero, right-click on your desktop and click "Personalize." A window of all the themes on your computer will open. You will see "My Themes," which are any themes you have created, and "Aero Themes" under it. To disable Aero, click "Save Theme" under "My Themes" to make your current settings default, or select one of the themes under "My Themes." This will make that theme the default. b> Troubleshooter b> If you still cannot figure out why Windows changes the theme back to the default after restarting, you can use Windows's built-in troubleshooter. The troubleshooter will find the source of the problem and automatically fix it for you. To use the troubleshooter for your theme, open the "Control Panel" and click "System and Security." Then click "Troubleshoot Common Problems." Under "Action Center," select "Appearance and Personalization." The troubleshooter will run. When you restart after it completes its action, your theme should stay the same. Hope this helps.
b>
1helpful
2answers
Hi I am using Nokia N78 smartfone When i go to Menu, Tools, Settings, General, Personalisation, Themes, to change wallpaper and themes it's hang and its restart itself. Im already did soft reset and...
Please remove the Memory Card and try again (try changing the wallpaper). In most cases, this problem is caused by virus or corrupted files saved on the Memory card (Maybe you didn't actually save them, but it's possible when transferring or in other ways). If even removing the memory card doesn't fix the problem, then please update the firmware or completely flash ( reinstalling the mobile's operating system) your phone. To do this, you better take it to a service center or to a mobile repairing shop, otherwise you may make mistakes which will be hard to get it work again.
Good luck.
Thanks for using FixYa.
49helpful
4answers
How can i download themes for samsung star
just google ur themes..there are many websites that do provode free downloads of themes...eg s jetjar dot com....u may even download from any other sites....after downloading jus put in ur memory card into ur memory card reader n copy the themes....or connect ur phone with pc and transfer it!!!
3helpful
2answers
Wallpaper
GO TO SETTINGS-general-pesonalisation-standby mode & turn it on now u can c ur theme graphics.tis is the only solution
I have got a problem in desktop icons i e all the icon are high lighted"what can I do for this problem.
Probably you have selected wrong desktop theme,
  • simply remove all all screensavers
  • remove desktop wallpaper
  • change theme to windows xp or windows standard
  • additionally readjust the virtual memory settings
Goodluck
Zulfikar Ali
Wallpaper and screensaver settings on desktop
Hi are you connecting the laptop to a lan , If yes it will happen because admin guys will have deployed from server.
Downloading theme
even I want some animated wallpaper themes for my rokr e6......i want themes like sony ericsson and cute screensavers......tried to put redado gifs as a wallpaper but its not showing me animation....somebody please help me.......
1helpful
Cant replace wallpaper
FOllow da steps
1>go 2 menu
2>themes
3>select whichever theme u want
4>go 2 options
5>edit
6>Select wallpaper as default
2answers
Cant remove my default nokia wallpaper
go to themes>edit>custom wallpaer (or something same)>browse to your chosen wallpaper...
give it a try,, and let me know...
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
