Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Hot to open a lacie porsche hard drive - LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
5 Related Answers
Anonymous
  • 287 Answers
SOURCE: LaCie F. A. Porsche Hard Drive
Try this...
use a long bladed kitchen knife to get carefully spread apart the sides from the bottom plate. there are 4 small tabs along each side of the case going int 4 slots on the bottom plate. The long sharp blade inserts easily between the side and bottom plate.
Carefully pry the side away from the bottom plate starting from the front working towards the back. You gently twist the blade to get the tabs out of the slots. the first one is the hardest. After that they pop out easy.
to remove the hard drive mechanism, once you have the bottom plate off, remove the four silver screws--two along each side--then use the knife to separate the sides of the hard drive from the case, so that the front of the drive is angled up (you'll also have to pull the activity LED loose from its hotmelt glue), then slide the drive out of its metal mounting bracket--you won't be able to pull the drive out along with this bracket.
Posted on Jul 16, 2008
Anonymous
SOURCE: Lacie 500Gb Hard Drive Porsche design
Hallo,
my disk, when on, is not recognised by Windows while the light is flashing between yellow and orange fast (like a car's flash -faster-). please could anyone help me? - i need my data!
Thank you.
Posted on Sep 29, 2008
Anonymous
  • 95 Answers
SOURCE: recover data from a non responsive LaCie F.A. Porsche Hard Drive
Does your drive make any unusual sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
If yes then you got a problem - it's something mechanical with the heads and it's not something you can fix by yourself.
If it sounds normal or doesn't spin up at all - try to connect it to another computer and if still no go - remove the internal drive from enclosure and connect directly to PC via SATA port.
Posted on Nov 11, 2008
Anonymous
  • 173 Answers
SOURCE: FW Lacie Porsche FW ext. HD 250GB light on case blinks and
conect your harddisk to computer whch has windows xp.
Then go to start emnu then type in run 'cmd"
then you can see command propmt.
Then go to your external drive letter like f:
then type 'chkdsk /r"
then pres "y'
then it fix error on hardisk.
Aslo you can format it .
Just take backup of data which you need then right clik on drive licon and format it.then it works fine.
Posted on Jun 23, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Posted on Sep 13, 2009
I have protools7 that wont load after I installed porsche design lacie 500gb hardrive
USB 2.0 is extremely slow for the purpose of doing direct recording. External drives are best used for backup after a project is done.
I have a lacie design by F.A. Porsche 250Gig Hard drive - It has failed and is making a buzzing sound follwed by a beep - is this repairable?
Sounds like the hard drive in the Lacie has fauled.
You can install a new hard drive in the Lacie and then format in FAT32.
Recover data from a non responsive LaCie F.A. Porsche Hard Drive
Hallo,
Thank you.
Shut down
Email me at : [email protected] and i will send instructions how to repair it
Lacie 120GB dropped
If you open it up you will see that the drive is a regular computer drive. You should be able to plug it into a computer as a secondary drive and try to get the data off. But if it's clicking and making noises there may be no hope. Sorry!
Lacie 250 GB USB drive problem
If you mean a Lacie-Porsche: Get a blade. Bottom is kept by 9 plastic clips along the long edges (5 and 4): you must insert the blade and force appart a little those lateral walls. After extracting the bottom pannel, unscrew your hdd and bend "up" (your device is upside down;-) those metal fingers. Rodeca P.S. Sorry, I'm tired and cannot write English properly.
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
Top LaCie Computers & Internet Experts
Ekse
Joaquim Martins
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
