Aspire 1700 needs to be acpi compliant, to run windows 7 help needed
On loading windows 7. loading stops with error message bios not fully acpi compliant, anyone come up with a solution to this problem
Posted by ali graham on
wizkid18
  • 125 Answers
Advanced Configuration and Power Interface
(ACPI) specification provides an open standard for device configuration and power management by the operating system.
Windows 7 absolutely requires ACPI 2.0 for power management.
Your laptop only supports ACPI 1.0. Windows 7 will never load
I think Vista is the most advanced version you could install.
I really like XP as the speed is so much faster.
Keep Smiling :)
Posted on Oct 25, 2013
1 Related Answer
Anonymous
SOURCE: Password
My stops at
Window could not start because of an error in the software
Please report this problem as
load needed DLLs for kernel
Posted on Jul 31, 2008
The bios in this system is not fully acpi compliant
Guess your computer is not compatible with Windows 7. Reinstall windows XP run compatibility test from Microsoft
May 16, 2014 | Dell Inspiron 15 (N5050)
BIOS Acpi Not Compliant
You will need to go to the website for the motherboard manufacturer and download the updated drivers for that motherboard. This is common with all the changes that windows goes through in a life cycle.
Nov 23, 2011 | Computers & Internet
A problem detected and windows has been shut down to prevent damage to your comp. I this is first time that u have seen this stop error screen restart pc. If this screen appears again follow these...
This happens when your operating has a problem with it's hardware, e.g or ram etc. Also some windows major files like DLL are gone missing by chance. Try to restart the Pc and press f8 until you get the options to start in safe mode, If safe mode dosn't works and gives the same informaton, try to make a backup of your filesby using the external hard drive, whereby you will need any other computer to make this backup, from your own hard drive. After doing this, you can format the hard drive and load operating system on it, if you know how to do this. You haven't mentioned the operating system you have in your pc, if you have vista or win 7. by pressing f8 key will aslo give you options, e.g..repair, run computer to last known configuration etc. Hope this works, or you can also go online help with service tech.
Sep 01, 2011 | Computers & Internet
Dell 8300 not loading xp home with the blue screen of death
To resolve this behavior, contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant.
To work around this behavior, manually install the Standard PC hardware abstraction layer (HAL):
  1. Restart the computer to restart Setup.
  2. When Setup starts again, press F7 (not F6) when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL.
Dec 30, 2009 | Dell Dimension 8300 PC Desktop
ACPI BIOS not fully compliant
w8000 a very old PC not supported by HP.
windows 2000 support ended like 15 years ago.. W2k. is gone. w2k only runs on very old pcs with very old ACPI
(power controls is that)
this PC is only supported with XP
never 2000.
HP tells you that if you looked.
park the 2000 disk or use it as frezzbee. IMO
https://support.hp.com/us-en/drivers/selfservice/compaq-evo-workstation-w8000/322279
id get w7 disk and use that, it might work.
but will cost you a license from MS,
about 5 times the value of w8000
why not just go here, and get used $20 w7 pc
save a bundle of case and grief messing with any legacy junk....avoid legacy junk and win.
http://www.pcdied.com/cheaper.html
a usa answers.... always...
Jul 19, 2017 | Compaq Computers & Internet
Acpi complaint - reg
I have located some info on this board. it was released as a "Medion" board
there is some BIOS and driver stuff available HERE
http://www.medionusa.com/ and select customer care.. you need the exat model no or the serial no of the PC to continue though.
Also http://www.treiber.de/ may me of assistance as I think they are the real manufacturer but as I cannot read German I cant really be sure. they have the link to Medion on their webpage...
HIH and please post back results
Jun 23, 2008 | Intel Motherboard
Password
Does it boot in safe mode?
To check, please follow the steps below:
1. Power on your computer
2. Immediately begin tapping F8
3. Keep doing so until you reach the Boot Options menu
4. Select Safe Mode
5. Press Enter
This will load windows using a minimal amount of drivers.
Jun 23, 2008 | Toshiba Tecra TE2300 Notebook
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
41
Jan 17, 2008 | Intel Motherboard
Problem istalling windows 2000 professional on a pc with intel d945gcnl motherboard
try to make bios settings default and make a proper installation
The bios in this system is not fully ACPI compliant. Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
Dec 04, 2007 | Microsoft Windows 2000 Professional for PC
Computers & Internet Logo
177 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
