Russell Hobbs RH1042 Frontload Washing Mashine Logo
Leanne Shipley Posted on Oct 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washing machine russell hobbs rh1042 gets half way in to a cycle then stops and lights start flashing what does this mean
Denny Giesel
Level 3:
Master:
  • Master 818 Answers
  • Posted on Oct 24, 2013
Denny Giesel
Master
Level 3:
Master:
Answers
818
Questions
0
Helped
152405
Points
2428
Your machine is trying to tell you something-do you have the owners manual-if you don't I'd bet you could find it online-what I would look for is an explanation of the flashings-it will probably tell you to count the number of flashes to tell you what is going on-cheers denny
Washing machine-making a loud banging noise when on spin cycle
sounds as though your load might be off balance, and I would make sure the tub springs are intact.
Washing machine starts washing then stops mid cycle
The clothes become very heavy once water is added. Please try remove some of the clothes to reduce weight Karen. Thank you and let us know if this helps? Leave feedback
Washing machine will not start, only get two red flashing lights, what could be the problem ?
Sounds like something toasted on the control panel
Better call certified appliance repairman
Washing machine keeps filling up with water kno matter what setting it is on even on the drain setting
You have a problem with your knob or switch it may be burned out I would get on Craigslist and find a free one meaning a matching one or a whole working unit there on there all the time in free stuff sometimes matching sets
Washing drum not rotating
More than likely belt gone, otherwise the motor has gone.
Flashing lights doesn't complete spin
I think this indicates a fault i.e. unbalanced load, I had the same when I tried to washable pillow. Went through all cycles but spin.
Which button is spin on my russell hobbs rh1042 washing machine
The second to last on the dial (picture of a spiral), if it's the same as mine.
Play sign flashing
Check to see if the exit hose behind your machine has fallen off. Check to see if the door has closed properly, your water inlet is open, etc.
Top Russell Hobbs Washing Machines Experts
john h
Are you a Russell Hobbs Washing Machine Expert? Answer questions, earn points and help others
