Question about Samsung LE26R73BDX 26 in. HD-Ready LCD Television
Samsung tv UE40D6500 is stuck on atv, i have tried to factory reset it by using remote: press info then, menu, then mute then power. but its still on atv and all the channels are messed up and fuzzy
Posted by nina Kristiansen on
Tom
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
There is a DTV/ATV button that switches between analog and digital tuners. Using the source button doesn't change it.
Posted on Oct 25, 2013
5 Related Answers
Panso
  • 4 Answers
SOURCE: Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Posted on Jun 10, 2008
Anonymous
SOURCE: Frozen digital screen
Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Posted on Jan 28, 2008
Anonymous
SOURCE: dtv
I followed your suggestion and it works! You certainly do push the
info
menu
mute
power buttons but I cannot remember the exact order.
I may have pressed them altogether, or in a quick sequence and it may have been in standby mode or switched on.
Fiddle with it, because it does work.
What will happen is that you will get a set of commands on the screen. Use the remote to get to RESET. At first I coudn't get this to work as I kept pressing the "enter" button in an attempt to select this option, but actually you just need to press the right arrow button to select it.
Reset comes into place. Wait a while and press a channel number, then just re-tune. You will have to re-tune anologue and digital. This works - please share with others. Eamonn
Posted on Jan 29, 2008
Anonymous
SOURCE: need help
ensure the tv is in analogue mode, not dtv and turn it off. with the remote: press info then, menu, then mute then power. these buttons need to be pressed sequentially not all at the same time and in quick succession. a menu will appear on the tv. navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button) the tv will reset itself and turn off. turn the tv back on & it'll re tune all its channels. DTV should be working again.
Posted on Mar 28, 2009
Anonymous
  • 6 Answers
SOURCE: SAMSUNG LE32R73BDX/XEU TV
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Posted on Oct 05, 2009
Reset settings factory defaults
Useing remote by pressing (info-menu-mute-power) turn off tv and press this bottons.you will get reset option on screen Thank you
Dec 07, 2013 | Samsung PCN5425R 54" Rear Projection...
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
Samsung flatscreen wont turn on but red light is on showing power ..my son used sleep timer last night
with tv in standby press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu DO NOT CHANGE ANY SETTINGS
look at list you will see reset
ONLY USE DOWN NAVAGATION KEY until RESET is highlighted
then PRESS RIGHT NAVAGATION KEY the tv will reset
PRESS STANDBY TO EXIT
the tv will need retuneing after
hope this helps
Dec 19, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung Le40a556 factory reset
with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on in factory menu settings look for reset use DOWN NAV KEY until highlighted and press RIGHT NAV KEY
to exit settings press standby the tv will come on and follow on screen instructions
DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK IF CHANGED
Dec 13, 2009 | Televison & Video
Factory reset Menu
IF A SAMSUNG TV Put tv into STANDBY
WARNING DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK
Press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu displayed and FACTORY RESET (12) is on it
ONLY USE DOWN NAVAGATION KEY until you highlight factory reset
NOW PRESS RIGHT NAVIGATION this will reset all settings
PRESS POWER ON THE TV TO EXIT then turn on tv and retune
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
I want to restart my samsung LCD TV LE32R71B, how can i do it?
You can reset 2 ways Put tv into analog mode by pressing TV/DTV on remote then press Menu move down to the satellite pic press enter you will see plug & play in the list press enter and follow on screen instructions
The other way
WARNING TV WILL NOT WORK IF YOU CHANGE ANY OTHER SETTINGS
With tv in STANDBY Press INFO / MENU / MUTE / STANDBY on remote the tv will come on with the factory settings displayed
FACTORY RESET ( 12 ) will be in there USE DOWN KEY ONLY until Factory reset is Highlighted then press the RIGHT KEY the set will reset all settings PRESS POWER ON TV TO EXIT
Turn ON TV AND RETUNE
Nov 05, 2009 | Samsung LE32R71B 32 in. HD-Ready LCD...
How do i reset factory sttings on samsung lcd tv
go into analogue tv press menu move down to settings you should be able to enter plug and play in menu press ok( if you can not enter it you are not in analogue )
if not solve problem try this !! warning !!
you will enter the service menu DONT ENTER OR CHANGE ANY OTHER ITEMS THAT ARE DISPLAYED AS TV WILL NOT WORK IF YOU DO
With tv in standby press INFO / MENU / MUTE / STANDBY on remote
then use ONLY DOWN nav-key move to number 12 FACTORY RESET
press RIGHT nav-key will reset all tv settings to factory ones
PRESS STANDBY TO EXIT on remote
you will have to RETUNE after tv after
Oct 25, 2009 | Samsung LN46B530 LCD TV
Channel stuck on TV
This may work;
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Feb 24, 2008 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Built in freeview locked up in tv
I also got a black screen! I then turned the TV off, pressed TV and while it was lit, quickly pressed info, menu and then mute. Then switched the tv back on and amazingly......the menu was there. Go to item 12 and reset. I am please to say that we are back in business,
Jul 12, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LE26R73BDX 26 in. HD-Ready LCD Television Logo
2,083 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
