SOURCE: No I need a screen for a LG LCD 42 inch TV . .My
a new screen is like a new tv $1000 - 1500 for a panel
SOURCE: MY LG 42 INCH LCD WAS DAMAGED THE SCREEN AN OBJECT
it depends on the severity to know what all is damaged, is the "object" embedded in the screen still, did it crack the screen, do you see anything on the screen, And we will need to have the exact Make/Model of TV to suggest any parts or prices/repairs, I'm sorry that happened to you, I am ultra paranoid about that happening to mine (52"), I hope this helps, please give a fixya rating if it helps solve your problem
SOURCE: what will i do to my damaged 42 inch LCD LG TV it
Check ur power sources?Yes,than tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
SOURCE: I have an LG Scarlet
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox,Sony, Panasonic, and others were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is itunder warranty?) 2. Open your TV and find PSB. (The board that the power cordplugs into) Check for faulty caps. If you find some (bulged or leaking) bad capsreplace the entire board. The entireboard costs around $250 right now because they are in high demand right now. Theycan be found at tv-part.com but supplies are limited. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this isyour board you are in luck. It'scalled: Fixingthe Philips Turns/shuts off on its own problem. I'm working on uploading pictures to helpguide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate it accordingly. Good luck.Kaufman605
