Anonymous Posted on Oct 24, 2013
My onkyo ta-rw414 left deck won't play. I found it
My onkyo ta-rw414 left deck won't play. I found it has both pressure rollers engaged when forward or reverse play is pressed. If I lift a pressure roller, it will play in the opposite direction. It rewinds both directions fine. It has a new belt.
paul girrbach
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 26, 2013
paul girrbach
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
251
Points
Cassette tape stops 5 seconds
2 Related Answers
petraman7
Scott Frye
  • 1175 Answers
  • Posted on Feb 09, 2009
SOURCE: Tape deck won't play.
Hi...
From being a Pro-tech and working on these and other like them I'd say it's the main belt+ idler wheel that has worn out.
Very challenging job to do..Like knightstar7 said
Anonymous
  • 1512 Answers
  • Posted on Dec 09, 2007
SOURCE: NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Onkyo TARW470 tape deck rewinds and fast forwards, but won't play?
Take it to a local audio repair engineer. There may be a broken drive belt. Or take the case of and take a look.
NEW 2 Replacement BELT SET* ONKYO TA-RW414 TA- ...
West Coast Belts https://westcoastbelts.com > Electronics
*NEW 2 Replacement BELT SET* ONKYO TA-RW414 TA-RW400 TA-RW470 DUAL CASSETTE Player ; Easy Returns. Quick & Hassle Free ; Dimensions, 6 × 6 × 1 in ; Compatible ...
US$19.99
https://www.google.com/search?q=Onkyo+TARW470+tape+deck
Onkyo ta
It may have a shorted capstan motor control transistor or it might be set in high speed duplicator mode. I need the model number to say more.
High pitch hum
The mechanism need work and so bringing it to a tape deck repair shop is the only answer if you want it to work again. Check the reputation of the place you take it to on the internet- a lot of places charge money but never fix the unit.
1helpful
Where can I find a repair manual to replace belts on my Onkyo Stereo Cassette Tape Deck TA-630d
I have found a service manual for you that can be downloaded free:
http://elektrotanya.com/onkyo_ta-630m-sm-tape-deck.pdf/download.html
After the page is appeared fully, click on this place:
Get Manual
Not logged in
Only 2 downloads
allowed a day
and the downloading will begin.
gylacz
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
My cassette deck Onkyo model Ta 2060 is working slowly
HELLO
By the fault you describe this sounds very much like a belt problem. Take the case off the deck and check the belt(s). Some decks can use more than one belt and you need to look at their condition.
Are they too slack around pulleys maybe? Belts don't last forever and I'm not too sure of the age of your deck. But personally, I would change them all.
Make sure the tape path is clean as well, clean heads, pinch roller and capstan.
Cassette tape spins fast
Hi Chris..
It's not worth repairing. I would find something else in good condition
1helpful
2answers
Onkyo TA-2700 - Won't Play Tapes
Open the deck and look for the copper colored leaf switches (above the plastic comb) that get corroded / dirty over the years.. Clean them with deoxide or similar and your are most likely good to go..
Onkyo TA-207 3-head cassette deck
The gearing and rubber parts involved in FF or REW vs. play are different. This unit should be overhauled and all of the rubber parts replaced.
Dan
 Grubhead
Grubhead
SmartAviator
SmartAviator
