Normally, the front loading machines come with a special stacking kit (that may be available separately). Now I wonder why one would put the washer on top! Most of the time the washer is put at the bottom making it easier for plumbing. Secondly, in case of a large spill, it would be safer to have the dryer on top due to the power required for the heating elements. I would therefore not recommend putting the washer on top even if that might be possible to do so...
100% NO. Washer weighs 300 lbs. Dryer probably about 100 lbs. Not to mention most front load washers spin out at 1200 rpm or so and the thing would shake and rattle and like crazy
SOURCE: my Maytag Front load stack unit washer/dryer model # MLE2000AYW
I had a similar problem, My washer spun but the clothes were still soaked with water. We replaced the inertia switch. That solved it.
SOURCE: removal of front panel of a stack washer and dryer mod
Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
SOURCE: is there a stacking kit and what does it cinsist
Please post the model number of both your washer and dryer.
That information is on a sticker around the door of both. Then I can provide you specific information. OK?
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
SOURCE: can i stack the Bosch front load washer with a
There is no stack kit to do what you propose. That said, you may be able to construct a compartment on top of one unit to accept the other.
