Question about Magic Chef MCBR440 Compact Refrigerator
Magic Chef Mini-Fridge not Working, Model # MCBR360S
My 10yr old son just rescued a Magic Chef mini-fridge from his friend's front yard trash pile. We plugged it in and nothing happens. Any advice on how to troubleshoot the problem? We are hoping its something as simple as a fuse, or it may find itself in our trash pile next month!!
Any advice welcome.
-Tommaso
Posted by texastommaso on
  • Anonymous Mar 29, 2014
    what is to hot on this magic chef fridge
John Tripp
  • Magic Chef Master
  • 4,656 Answers
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
Posted on Apr 27, 2009
  • BREEZE Sep 13, 2017
    I just RESCUED the SAME MODEL, MINE however is NOT COOLING BUT IT' S Running Quietly as you said.
Are the 2 copper lines coming off of the compresser suppose to have crimp in them? and are they suppose to be touching each other??,
Yes the crimp is normal. These are ports used in the factory for charging and testing. Touching is OK
Sep 19, 2017 | Magic Chef Refrigerators
What could be the problem with my Magic Chef mini fridge model number MCBR465S. It comes on when I plug it in but not cool at all, and the compressor hot, could I trouble shoot and how,freon? Thx
If the compressor is actually running and there is no refrigeration, I would suggest it has a gas leak and that's why it isn't cooling. Depending on what type of refrigerant is in it, it may not be worth repairing as its only a small bar fridge? Check the rating plate to see if its R12 (Older fridges) or R134A . If the unit is less than 5 years old, it may be operating on R32 or R600 (Butane refrigerant gases) If its only a couple of years old, it may still be under Manufacturer warranty. Most fridges carry a 2 year warranty on everything and up to 5 years parts warranty on what is known as the "Sealed system"
Apr 19, 2015 | Magic Chef Refrigerators
I have Model No. MCBR360S Mini Refrigerator- It Quit working - The compressor was pretty warm. I keep hearing a Click.
That clicking sound is the compressor trying to start, if it is less than a year old just call magic chef and they will replace the unit, if not the cost of a sealed system repair may make it not worth reairing
Sep 11, 2010 | Magic Chef MCBR440 Compact Refrigerator
My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Oct 20, 2009 | Refrigerators
Fridge won't start, tries to but clicks off after a few seconds
compressor is broken if you are under warranty you can get it replaced. if not you should buy another one cause compressors are expensive to replace. costs about the price of a new refrigerator. you can try getting a used one from classifieds or craigslist.com
Aug 26, 2009 | Magic Chef MCBR440 Compact Refrigerator
My mini fridge will not work. compressor is hot.
Believe you need to change the start relay and overload, Sea Breeze
Aug 23, 2009 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef MCBR440 Compact Refrigerator Logo
4,476 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
