Raw file system
To fix the problem
Disable the S.M.A.R.T error detection feature in the CPUCool program or similar utility.
Boot to the Windows 2000 or XP installation CD, and at the Startup menu, press R for repair.
In the Recovery Console, type the following:
chkdsk /p
When the CHKDSK process has finished, reboot the computer.
Run the program again.
The error should no longer be reported unless you start using the S.M.A.R.T error detection feature again.
Error occurs with PartitionMagic 8.0
If you encounter Error 1516 with PartitionMagic 8, first run CHKDSK /F on the affected partition. For instructions on how to run CHKDSK, read How to Run Microsoft's CHKDSK from the Command Line. If this does not fix the error, try running PartitionMagic with the /IFC switch, which causes file system errors to be ignored.
To run PartitionMagic with the /IFC switch
Boot from the first PartitionMagic rescue disk.
When you are prompted to insert the second rescue disk, press Ctrl+C to drop to the command (A:>) prompt.
Insert the second PartitionMagic rescue disk and type the following:
pqmagic /ifc
Press Enter.
please go ahead and try the above steps may be it will fix it
