Televison & Video Logo
Question about Sanyo AVM-2506 TV
Need new cable connection housing for 1996 Sanyo TV NXC0025
1 Related Answer
Raditronic
Radames Pagan
  • 196 Answers
SOURCE: SANYO TV
This plug no solder, you need a RCA connector # SK25FCON. THIS PLUG ACCEPT SOLDER
Posted on Jan 31, 2009
New Sanyo TV put in with existing cable box using HDMI cable plug the tv in and it won't load the channels? The cable box recognizes the Sanyo. Why aren't the channels loading?
Hi Paula, check the HDMI input, on the Sanyo TV, where the cable box is connected, it is assumed that the channels are loaded in said box
Hola Paula, verifique la entrada HDMI, en el televisor Sanyo, donde esta conectada la caja de cable, se supone que los canales est?n cargados en dicha caja
How do i hook up a sanyo tv to an lg sound bar
You can't There is no way. You need a sound bar that connects to the audio out or monitor jacks on the TV.
I have a Sanyo Tv model # SC31520 that dose not have a Cable jack on the back how do I hook it up to the Cable if it does not have a cable jack on the back
You will have to purchase cable that was once used to connect an older VCR to the TV. This cable connector will go into the RF connection of the TV to the RF connection on the cable box. If the RF connector you are looking for in the back of the TV is gone...you will have to find a TV tech to attach a new RF connection to the tuner of this TV. Hope this will help with a solution!
Static after moving 13GP300 from one cable connection to another
try checking that the coaxial cable is inserted all the way. or it could be the wiring behind the walls on that side of the house is interfereing with the reception. or is there something else plugged in the same out let that wasn't plugged in in the opposing location? that could be causing issues as well. but first check the coaxial cable going into the back of your tv or cable box.
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
My Sanyo DVW-6100 does not work afterchanging to Dish Network
Sounds to me very much like the installer messed up. I would begin by confirming that there are absolutely no cables to the Sanyo, which if you checked the back is unlikely. I have never seen connections anywhere but teh front and back of anything other that a TV or game system. Once you are confident that the system is not connected, contact his company and inform them that he failed to hook that piece of equipment back up. It is their responsibility to make sure that it gets done.
Cable
did you try to connect your tv to another source in the house.if you have cable anywhere else. try to connect your tv to that cable.if that works you might have to buy a new cable for your tv.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
