Canon i80 InkJet Printer Logo
g
gregory collier Posted on Oct 24, 2013
Service manual the printer is saying Service error 5100. Cancel printing and turn the printer off and then on again. If this doesn't clear the error, see the printer manual for more detail what can I do to solve this nothing is working
arfe ardiente
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Oct 24, 2013
arfe ardiente
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
6430
Points
16
Look up the printer tray sir.... if you see a lots of paper inside the tray removed it.. then try again printing... or else... try to change the printer mother board...
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on Nov 20, 2007
SOURCE: Service error 5100.
Had a same problem, here is what i ve received from canon support:
"Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
Please be advised that error 5100 indicates a carriage error and the machine will require service."
However I managed to solve it by myself by perform few paper path tests as there was a paper jam inside.
Anonymous
  • 6 Answers
  • Posted on Jun 12, 2008
SOURCE: Service error 6A00 Cancel printing and turn the printer off and then back on.
plese help me free
Anonymous
  • Posted on Nov 09, 2008
SOURCE: Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
pineworks
Clive
  • 4362 Answers
  • Posted on Feb 10, 2010
SOURCE: please problem solve
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mykel_N
Mike Neath
  • 315 Answers
  • Posted on May 27, 2010
SOURCE: Service error 5C00.
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in succession. Note: you are still holding the POWER button). The printer's carriage will “reset" or move momentarily.
If the above was properly performed the printer will enter the "Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp will alternate (change) color with each key press. Next press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
The problem with resetting the waste ink counter is that the waste tank could at some point over-flow. If you manage to get inside to empty the wadding and waste ink tank, make sure you wear rubber gloves as the ink will get everywhere..
And make sure you replace with some fresh wadding if you can..
Regards
Mike
5helpful
2answers
I can't print in my Canon Pixma IP1980... service error 5201. cancel printing and turn the printer off and then on again. if doesn't clear the error, see the printer manual for more detail. how can i fix...
service error 5201. cancel printing and turn the printer off and then on again. if doesn't clear the error, see the printer manual for more detail. how can i fix this?
Service eror
Hello my friend,if you mean Service Error 5100 then you must know that i caused because the movement of the Print Head Holder is blocked.So you must clear the paper jam or foreign object that is preventing the Print Head Holder from moving. Cancel printing from your computer, then turn off the machine, and turn it back on again.Let me know the results:)
9helpful
2answers
Service error 5100 on canon prixma mp198
Service Error 5100
Cause : Movement of the Print Head Holder is blocked.
Action "Clear the paper jam or foreign object that is preventing the Print Hed Holder from moving, cancel printing from your computer, then turn off the machine and turn it back on again.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Hi, I am trying to print a report and I get a service error 5100. I have cancelled print job and pressed ok, done this a number of times, still get the error, please help
Service Error 5100
Cause : The movement of the FINE cartridge Holder is blocked.
Action : Clear the paper jam or foreign object that is preventing the FINE cartridge Holder from moving, cancel printing from your computer, then trun OFF the machine and turn it back ON again.
Hope this helps. Pllease rate my Response.
Thanks.
Have a good day. .top3Module { BACKGROUND-IMAGE: url(/images/Reviews/Top_3_BG_Asset.jpg); WIDTH: 310px; BACKGROUND-REPEAT: no-repeat; MARGIN-BOTTOM: 15px; HEIGHT: 361px } #RNR_rpt_div A { COLOR: #0033cc; FONT-SIZE: 12px !important; TEXT-DECORATION: none } #RNR_rpt_div IMG { VERTICAL-ALIGN: middle } .toptitleBest { MARGIN-TOP: 19px; FLOAT: left; COLOR: #4f81bd; MARGIN-LEFT: 19px; FONT-SIZE: 18px; FONT-WEIGHT: bold } .wrapperDiv:hover { CURSOR: hand } .wrapperDiv { FLOAT: left }
2answers
Error 5100 I had a paper jam, and didn't turn the printer off before I pulled it out. Roller doesn't appear to be moving.
Service Error 5100
Hope this helps.
Thanks
Have a good day.
I have a cannon printer mp160. I'm trying to print a document but I keep getting a service error 5100 message
Service Error 5100
Thanks.
Have a good day.
1helpful
Last week i tried to print but it didn't work and appeared 5100 error. i have the pixma mp 170 printer... i don't know how i can fix it
Hello
The manual states that the error code 5100 is a result of:
Service error 5100 is displayed
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
If this does not work, try resetting the device:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Hope this can help you.
Best regards
Andrea
9helpful
5100 ERROR
As per the manual...
6A00 Service Error
Service error 6A00.
If this doesn’t clear the error, see the printer manual for more detail.
3helpful
Error 5100
Service Error 5100 is Displayed
Cause
Action
old marine
old marine
ZJ Limited
ZJ Limited
