SINGER 7470 Sewing Machine Logo
E
Ernestine Posted on Oct 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Adjust timing MY NEDDLE TOUCHES THE BOTTOM OF THE BOBBIES CASE, WHAT MUST I DO
josephamoi
Level 2:
New Friend:
  • Expert 130 Answers
  • Posted on Oct 24, 2013
josephamoi
Expert
Level 2:
New Friend:
Answers
130
Questions
Helped
30254
Points
202
Presuming your needle is clamed in fully up position & is not needle bar height problem,this needle/hook timing should get your local sewing machine technician to get it adjusted correctly.
My model H-74 the bobbin case keeps popping out causing the neddle to hit
It may be best to take it for service. It could be out of time or have other issues that a knowledgeable technician can address.
How to fix timing on Kenmore 70 sewing machine
Try talking to the people at the link I attached. There are about 7 different adjustments to fix timing issues. Good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Neddle hits bobbin case while sewing zig-zag stitch on Pfaff 7570
insert the needle all the way up or, lift the needle shaft or readjust the timing
The neddle is hitting the medal instead of going in how do I adjust this problem on a brother es 2000 machine
Check to see if the needle is bent. If that is not the case you need to adjust the needle position on the needle bar. This may be something that you want to have a technician do, so you don't change the timing on the machine.
Were my bobbins goes it has a bobbin case but the case makes the machine stop and breaks the neddle what can i do
you are useing the wrong needles for the machine or the needle bar that holds the needle has slipped down from its retainer. and it will need the timing done. with the bobbin case out you will be able to see how much shorter the needle will need to be or how much the needle bar will need to move up. the hook that picks up the thread should line up above the eye in the needle on the up stroke
Seat the bobbin & adjust tension on Singer 9018
basic tension instructions apply...bottom tension should be moderate, thread should pass when holding thread and dangle the case. Top tension should pull bottom thread JUST to the top side of fabric. thread bobbin case counter clockwise.
2answers
Timing the needle
That isn't the timing. If the hook is hitting the needle the hook is too far left - or close to the needle. It's adjustable by loosening the set screw at the base of the hook and by gently tapping the hook away from the needle. You want the hook to be close enough to the needle to pick up the thread loop that's formed just as the needle bar is rising.
1helpful
Neddle problem
Sounds like the needle is hitting the bobbin casing. Take it out and re-seat it. Check your manual.
Neddle screw wont tighten neddle in
There is a small metal rod about 1/2" long that fits into the hold in front of the screw that holds the needle secure. I didn't realize that I had dropped the rod until I could not tighten the needle. I found the rod, put it into the hole and was able to tighen the needle.
Sewing machine struggling to run or sewing slowly with no load
sounds like it needs oiled.
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Oiling instructions:
You never need a diagram to oil a sewing machine. Turn the hand wheel and look for every area that metal touches metal. 1-2 drops (more Is Not better) of oil everywhere metal rubs metal, use a flashlight and look and oil look and oil until every spot is oiled.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
