Apple iTunes Logo
Question about Apple iTunes
Can't get itunes to work
When trying to open itunes, the error "the folder itunes cannot be found or created. The default location for this folder is in the music folder" The itunes folder is in the music folder! Unsure why this is happening
Posted by micka31 on
  • Anonymous Mar 12, 2014
    I press my iTunes app and it just backs out
Raymond Ramirez
  • 333 Answers
The error message “The folder iTunes cannot be found or created”. It was referring to the My Music directory that is usually located in the My Documents folder on the partition containing the operating system. The iTunes software creates an iTunes folder in the My Music directory on first start and if that directory is not accessible it will throw the error message and fail to load.
Since this error is related to the My Music folder it is important to check the directory path of that folder in the Windows Registry. This is best done by using the shortcut [Windows R], typing [regedit] and hitting the [enter] key.
The fastest way of location the two locations that contain path information for the My Music folder is to use the search by pressing [F3] and entering [My Music] in the search box. A click on [Find Next] will start the search and reveal the two locations.
The test computer system did not have path information listed at all. This can be changed by double-clicking the My Music key in the Registry and changing the path to an valid path manually.
The two Registry locations that list the My Music path are the following two:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
Make sure both point to a valid path on the system. Once the path has been changed iTunes will create the iTunes folder in that location and start up without this error message.
Please back up your registry before doing this. messing in the registry can make your computer stop functioning.
Make sure you follow the correct registry entry.
Posted on Apr 27, 2009
2answers
Every time I try to open itunes it says "itunes stopped working and was shut down" I even tried re installing it with no success
You should try this:
Follow the steps below to create a new user account in Windows Vista
From the Start menu, choose Control Panel.
  1. Open Add or remove user accounts (If using the Classic View in Windows Vista, open User Accounts. Then open Manage another account).
  2. Select Create a new account and follow the instructions to complete the account setup process.
  3. Once the new account is created, choose Log Off from the Start menu.
  4. Log into the newly created user account.
  5. Open iTunes and determine whether the issue you were experiencing persists in this new user.
If still it doesn't work than follow the folllowing steps:
  • Remove iTunes Plug-ins
    Third-party iTunes plug-ins can cause many issues, particularly if the plug-in has not been updated to be compatible with new versions of iTunes. iTunes plug-ins are stored in the following location:
    C:\Users\username\AppData\Roaming\Apple Computer\iTunes\iTunes Plug-ins
  • Remove iTunes Preference files
    Some of the files that iTunes uses to store settings and preferences may be unusable and cause issues. iTunes has two folders where preferences are saved. Move one of them to the desktop and test to see if the issue persists. If it does, move it back and remove the second folder. The location for the two preference folders are:
    • C:\Users\username\AppData\Local\Apple Computer\iTunes
    • C:\Users\username\AppData\Roaming\Apple Computer\iTunes
  • 0helpful
    2answers
    Can't open itunes
    You need to reinstall Itunes and point it towards the correct drive/folder again. When you attached the second hard drive it would have fouled the pointers in iTunes.
    I have a classic iPod 80Gb. I have just loaded iTunes v8.1 onto my laptop using Vista home. When I try to ope iTunes the following message comes up:"The folder iTunes cannot be found or created and is...
    Uninstall the egzisting itunes by following steps. Start menu> Control panel>click on the Control Panel home on the upper left side>same windows you will see the programs and under Unisnstal a program waith for list of programs refreshes highlight Itunes and press the Uninstall tab and reinstall the Itunes
    1helpful
    I combined 2 partitions into one partition using Partition Magic
    In iTunes under preferences, you can go to the Advanced tab and specify the new location where you moved the folder to. By default it puts it under My Documents/My Music/iTunes Music. If you've messed with what drive that's on you need to change it in iTunes so it knows where it is.
    ITunes won't open
    Go to "Preferences" in iTunes and change the music folder location to the location on your new disk drive. Click the boxes as shown below:
    image.tiff
    2helpful
    2answers
    Disk is Locked Error
    If the My Music folder is in the wrong location or incorrectly assigned in the Windows registry, you may see one of the following error messages:
    • "The folder iTunes is on a locked disk or you do not have write permissions for this folder."
    • "The folder iTunes cannot be found or created and is required. The default location for this folder is inside the Music folder."
    If you see one of the above errors, follow these steps to troubleshoot this:
    1. Verify the location of your Windows XP My Music folder. The default location for this folder is
      C:\Documents and Settings\username\My Documents\My Music
      If you do not have this folder at the default location and have not moved it to another location, consider creating one inside your My Documents folder.
    2. Download and install Tweak UI from the Microsoft PowerToys website at http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx Note: This utility is for Windows XP only. Please review the system requirements before installing.
    3. Once you have installed Tweak UI, open it from the Start menu.
    4. In the column on the left, click on the plus symbol (+) next to My Computer and select Special Folders. ht1866_01.jpg
    5. In the right pane on the Folderlist, click My Music.
    6. Click the Change Location button. You may see a warning message appear with precautions for changing this setting; after reviewing the message, click Yes. ht1866_02.jpg
    7. In the resulting window, browse for the My Music folder as described in step 1, and click OK. ht1866_03.jpg
    8. Reinstall or open iTunes.
    Itunes
    you are using this computer as a limited user get the guy who is using this computer with the administrative rights to create this folder for you while use his account, i.e. make the file to your user acoount application data for you and then you try in your account.
    Or the guy can just run the setting for loading itunes in your account using the run as option for him(or her) to create the folder for you.
    The idea is where this folder is supposed to be created you dont have access rights to create the folder in your name.
    ITouch & iTunes
    Firstly you will need to create a folder in 'My Music' and Rename it iTunes.
    Write Back And i Wll Tell You The next stage.
    Top Apple Computers & Internet Experts
    Paul Carew
    Paul Bade
    Marvin
    Marvin
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
