Error E. OH (overheat power module) on a KEB F5 Inverter indicates that the power module is overheating. This can be caused by a variety of factors, including a malfunctioning cooling system, a faulty power module, or a problem with the wiring or connections.
To troubleshoot the issue, you can try the following steps:
Check the cooling system for any visible signs of damage or malfunction, such as a clogged air filter or damaged fan.
Check the power module for any visible signs of damage or malfunction, such as burnt or damaged components.
Check the wiring and connections to ensure that they are secure and properly connected.
Check the F5 Inverter's fuse and circuit breaker to ensure that they are functioning properly.
If these steps do not resolve the issue, it's best to contact a professional repair service or the manufacturer for further assistance. They will be able to diagnose the problem and recommend the appropriate repairs. It's also a good idea to stop using the F5 Inverter until the issue has been resolved, as continuing to use it may cause further damage.
Here is an overview of the the items required to communicate with the KEB COMBIVERT F5.
***X4A and X6B connections require special cable from KEB. This is a 24Vdc connection and will damage your PC/inverter if the proper cables are not used.**
If you are experiencing a "Display Power Not found" error on your KEB F5 Inverter and the DC bus voltage is coming and the control card is functioning properly, there may be an issue with the display or the power supply. Here are a few steps you can try to troubleshoot the issue:
Check the power supply for any visible signs of damage or malfunction.
Check the display for any visible signs of damage or malfunction, such as cracks or loose connections.
Try resetting the F5 Inverter by unplugging it and waiting a few minutes before plugging it back in.
If you are connected to the inverter with COMBIVIS, go to parameter FR.01 and enter a value of -4. This will set all parameters back to factory default.
You may be having an issue with the inverters software verison. As long as the inverters are the same part number, you should be able to download the parameters without any issue. There may be some unknown parameters but you should be able to hit ignore and keep on downloading.
