Question about Beverage-Air MT45 Beverage Cooler Commercial
I replaced th compressor on my Beverage Air cooler the tag calls for 18.5 oz. R-12 The new compressor is R-134a Does it take the same amount of refridgerant?
Posted by runyanssunoc on
Marat Brikov
    Director Badge:
    Uploaded 100 video answers.
  • Beverage-Air Master
  • 506 Answers
process of replacing compressor on beer cooler. Hope that helps.
Posted on Aug 25, 2015
Luis Calderon
    New Friend:
  • 146 Answers
Did you replace the filter dryer and vaccum? and the best way to go is by temp on your gages that will give you the pressure on the scale wich is about 28.5 for a 30degree temp.
Posted on Oct 24, 2013
3 Related Answers
SolutionGuy
Tracy Farrell
  • 331 Answers
SOURCE: bev air cooler
Bill, the main reason I've noticed for higher than normal temps in these boxes is filthy condenser coils (this will affect pressures in your sealed system). Remove the front lower panel and inspect your coils. Use a coil brush or a dust broom to thoroughly clean them up, don't use water. You can also pick up some condenser coil cleaner in a spray can from your local appliance parts store, but it's not necessary (the fumes are strong and may be objectionable to your customers... it gets 'em really clean, though!) After cleaning the coils, allow 24 hours for temps to stabilize. If they don't, here is a site for Beverage-Air, contact your local servicer with you exact model and serial number for pressure specifications. http://www.beverage-air.com/technical.service.html Hope this helps! Let us know, will ya?
Posted on Aug 13, 2007
espressonist
espressonist
  • 1711 Answers
SOURCE: PIZZA PREP TABLE BEVERAGE AIR
If you had a repair person to replace the compressor the you should not need to anything more. We believe the repair man have check also of the evaporator and condenser were working ok since from what we undestand he did not mention that they have any problems. So the problem is either the compressor starting kit is not working properly or the repair man left some wires loose. The second posibilty the freon charge is not the proper one and need to be check again if the gas pressure low and high are ok. Finnaly every time we replace a compressor on comercial refrigerator we also replace the freon gas filter if he didn't then there is a posibilty after the compressor replacement the filter to be goggle. As you have already notice from repair person in order to deal with freon gas you need special tools and also you need to have a national licence. Also if you have paid so match money for the compressor replacement then you should demand from them to check why the fridge still have problem to low down the temperature, if they have done a poper jop then the fridge would work better than before.
Posted on Aug 31, 2011
David
  • 4 Answers
SOURCE: What does the overload relay look like a
Normally thermal overloads have a button like appearance on the compressor. Designed to open circuit when temp has caused distortion to the bi-metal contacts. Upon cooling will close again. Disconnect power before checking continunity on the overload terminals.
Posted on Nov 18, 2011
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
How much oil goes in compressor
Are you replacing the compressor, or just reinstalling the old one?? For a new compressor I added one small can of oil - 4 oz? - and two cans of r 134a, 12 oz.
Feb 19, 2015 | Air Tools & Compressors
Qbd beverage cooler model dc7hg how many oz. 134a to recharge ?
The tag with the model and serial number states what the charge is. You might want to take a closer look.
Jul 03, 2014 | True Refrigerators
Does anyone know how many cans of freeon it takes to charge the air conditioner
It depends on what size cans of freon you are getting and if the system has been retrofitted for R-134A refrigerant (1992 came originally equipped with an R-12 system). The factory specifications call for 1.8 Lbs. of R-12. If it has been retrofitted for R-134A, the general "rule-of-thumb" is 85% of the R-12 specification is needed to charge the system with R-134A. So if we do the math: 1.8 Lbs (R-12) X .85 (R-134A) = 1.53 Lbs. R-134A needed for a full recharge (providing the system is COMPLETELY empty. Then you will have to find out how much is in each can that you plan to buy and do the math to figure out how many cans you need. (some have 12 oz., some have 14 oz., some have 16 oz., some have 19 oz. and some have 22 oz.)
Jun 16, 2011 | 1992 Honda Accord
What refrigerant is use for BreeZaire wkr 1060 and
A WKR 1060 SHOULD BE AN R-22 REFRIGERANT UNIT AND IT SHOULD STATE SO ON THE UNITS TAG ON BACK OF THE UNIT.
I IT IS IN FACT AN R-22 MODEL 1060 IT USES 9oz OF R-22
IF IT IS AN R-134A IT USES 10 oz
Dec 02, 2010 | Breezaire WKCE 2200 Wine Cooler
Can you advise what type and amount of refrigerant is in Breezeaire 6000 wine cooler?
TYPE OF THE REFRIGERANT IS LOCATED ON THE TAG ON THE BACK OF THE UNIT IT COULD BE AND R-22 OR AN R-134A
AND IT USES 22 oz OF REFRIGERANT WHAT EVER THE TYPE THE UNIT IS.
Nov 26, 2010 | Breezaire WKE 6000 Wine Cooler
Beverage Air model DP93 tag states 9.5 ounces of R134A however seems undercharged when this amount is weighed in and immediately becomes effective with a few more ounces. Could the tag be wrong???
It's been my experience that in most cases, it is very difficult to get the exact amount in that is on the tag. A 5 ft. hose can hold up to 3 oz. of liquid and on small systems, it will drive you nuts. Always go with what you know. Charge the unit to proper pressures and watch it for a while to see if it is doing what you want. The charge may have to be 'Tweeked" to get it right.
Jul 14, 2010 | Beverage-Air DP93 Refrigerator
My mt 12 cooler doesnt blow cold just warm air
thermostat could not be set properly, compressor could not be running, unit could be low on freon. start checking some items and let me know.
Aug 03, 2009 | Carrier Beverage Air® Marketeer® MT12-1-B...
Can R-134a refrigerant be used on a 1992 Camry A/C system
Hi. To answer your question, yes and no. If it has R-12 in it, it needs to be removed, or, as we call it, evacuated. Then, you buy a new kit that has everything you need to adapt the R-12 fittings to the new style R-134A fittings. Then, after the system is empty, add th 134A. We do not recommend that you put R-134A into a system that already has R-12 in it. You could damage the compressor.
Jul 15, 2009 | 1992 Toyota Camry V6
Wont cool
1. try cleaning the condenser it's gotta to have some dirt.
(if it looks clogged, turn the unit off and spray the condenser with a water hose!) it should throw out some dirt
if you did step 1 and still no cooling suspect a small refrigerant leak.
most of the times if its r-134a, i go down to autozone and buy a stop leak for r-134a and charge it into system.
also if theres a refrigerant leak,i'd get a tech to check and correct leak (if he finds it) but that's worse case scenario :) I'd go with dirty condenser.... email me at [email protected] if you need more info.
Apr 23, 2008 | Beverage-Air MT27 Beverage Cooler...
Beverage-Air MT45 Beverage Cooler Commercial Logo
269 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
