Question about Sharp AL-1631 Digital Laser Copier B/W Copy Machine
Sharp AL-1631 copier does not turn on. Changed outlets; checked all doors closed and latched properly. Copier does not power up. No lights, no sounds, no error codes. No nothing.
Posted by Howard Ellegant on
san3409jl
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
If copier power supply ok then replace MCU
Posted on Dec 25, 2013
3 Related Answers
Anonymous
SOURCE: I have a Sharp ARM350N
it is scanner out of position, swich off then swich on it should reset it.
Dave Moore
right document solutions
02074664700
Posted on Jun 04, 2008
john martin
  • 9 Answers
SOURCE: error code H 4 on
hi , the problem is with the fuser unit in the machine but it may be possible to reset.Try this : enter buttons "clear" , "exposure" , "clear" , "exposure" ( in that sequence ) the display will then blink. Enter numbers 1,4 and then press "print" button , followed by the "clear" button several times to get out. power off/on machine from main switch and problem should reset so long as heating element within fuser is not blown. hope this helps.
John
Posted on Jun 14, 2008
Anonymous
  • 148 Answers
SOURCE: alternating 4 - h on
To perform the reset for the H4 do the following:
Find the Clear button on the Control Panel.
Find the Auto button.
Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
Then,
Press the [10's] key one time and the [1's] key four times to enter so the number '14' is in the LED Display, as if you were to make 14 copies.
Press the green [Start] button.
Press the [Clear] button two times.
The machine should now warm up and come to ready.
If the above steps do not clear the error code You may need to have a tech look at this.
Hope that helps...
Posted on Jun 26, 2008
I am getting a ch message on my sharp al-1631 copier and can not find the manual. Do you know what this means?
CH stands for close hatch check that the front and side doors are closed. (open both then close again)
Jun 21, 2011 | Sharp AL 1631 Copier
When i close the back door it is making a loud noise. sharp al 1631
If it sounds like gears grinding it may be the fuser unit. The bushings and gears need replaced or new fuser unit.
Aug 31, 2010 | Sharp AL 1631 Copier
My al-1631 gives blank copies. just replaced toner. no warning lights of any kind. no message lights. it just prints out blank paper. could it be the drum? can't find instruction manual. purchased...
Was the copier working fine before you changed the cartridge? If so I think your cartridge is the problem. If it started making blank copies right after you changed it. If this is not the case the first thing I would say is it is not the drum. Try opening and closing the right side door. There are contacts in the door that will cause blank copies. I have had several customers do this and it fixed the problem. You can also try pulling out the toner and then pull the drum unit partially out and re-seat it. Then re-install the toner.
Good Luck
Jan 05, 2010 | Sharp AL 1631 Copier
Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Oct 16, 2009 | Sharp AL 1631 Copier
What does flashing CH mean?
Flashing CH means that the developer unit is not installed inside the copier or its not well installed. Check and install properly.
Aug 24, 2009 | Sharp AL 1631 Copier
Sharp al 1631 error code "CH"
it is signal door open or cartridge unite not atast
Jul 24, 2009 | Sharp AL 1631 Copier
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
Blinking error light CH will not let machine turn on
side door of copier is open just close it properly .if error stills just check by pressing start key what is sub code if 00 developer unit is missing if 01toner catridge is missing .just check all connectors of developer unit and toner unit.code will bi removed
Jan 20, 2009 | Sharp AL 1631 Copier
Green blinking light CH
That is no problem .CH is for that side door is open .just close it or check side door sensor it is dirty clean it .MIAN AKHLAQ
Dec 24, 2008 | Sharp AL 1631 Copier
Sharp AL-1631 Digital Laser Copier B/W Copy Machine Logo
77 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
