Question about Howard Miller Home
Howard Miller wall clock 620-474 How to attach pendulum and put batteries in when starting up?
1 Related Answer
Bruce Robin
  • 300 Answers
SOURCE: I need a Howard Miller battery mantle clock
Try www.klockit.com. You can replace the entire movement for about $5 including new hands. You can select from an assortment of hands that will probably match the style of what you have and use those if the old hands don't fit the new movement. I've bought several movements from them over the years. For a few more dollars you can upgrade to an "atomic clock" movement which synchronizes with the US time signal and even sets DST automatically.
Posted on Apr 15, 2010
I have a Howard Miller model 610-363. It chimes between the quarter hour. About 9 minutes early.How do I fix that?
OK, google is your friend, but before I go there, recognize that pendulum clocks are generally regulated by the speed/period of the pendulum. A shorter pendulum has a shorter period/faster time and vice versa. So in general, look for the length adjustment of the pendulum weight.
Specifically, here is a link to a google-d search:
http://www.howardmillerusa.com/customer-support/how-to-setup-howard-miller-grandfather-floor-clock.html
Dec 02, 2017 | Home
I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
Howard Miller Grandfather Clock
Dec 06, 2016 | The Watches
I purchased an older Howard Miller clock and the clock is keeping time but pendulum is barely moving. What do I do?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick. Howard Miller Grandfather Clock
Dec 06, 2016 | Home
Just bought a Howard Miller 620-160 wall clock. The pendulum is not swinging! What is wrong?
First thing to check is for locks that are put in when shipping so that it wont be damaged. If it is battery powered, check the battery.
Apr 02, 2016 | Watches
Keeps stopping
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling.
http://usedclockparts.com/8-clock-movement-repairs/39-how-to-easily-clean-and-or-fix-your-clock-movement
Sep 07, 2013 | Howard Miller Westmont Oak Yorkshire...
Changed battery and now pendulum wont swing. Clock doesn't operate at all. All was fine until I changed the battery.
Give the pendulum a shove and do it every time you pass the clock. I got mine going from swinging for just 20 seconds to working permanently, at least until the next battery change.
Jul 07, 2009 | Howard Miller 645-627 Clock Radio
Home Logo
65 people viewed this question
Top Howard Miller Home Experts
john h
Tom Chichester
Are you a Howard Miller Home Expert? Answer questions, earn points and help others
