Press the FAN & the up arrow @ the same time to get into installation programming. Follow the set up numbers correlating to options in the install instructions...Make sure it is programmed for heat pump & if you have Auxillary heat. Hit Next until you get to the reversing valve position O or B ( reversing valve energized in a call for heat or cool) and switch it to the opposite of what is in the current program. Hit Done & you should be good.
?? Connect Wires 5.
Labels don't match?
If a wire does not match any terminal on the thermostat,
see next page.
Quick Installation Guide
6
Alternate Wiring
If a labeled wire does not match any terminal
designation, see diagram below.
Do not use C, C1 or X wire. Do not use B wire if you already
have O wire. Wrap bare end of wire with electrical tape.
This thermostat cannot be used if your old thermostat had
any two of the following wires: R, RC, RH, 4 and V.
Place a jumper (piece of wire) between Y and W if you have
a heat pump without auxiliary/back-up heat.
?? Connect Wires (cont'd)
Programmable Thermostat RTH2300
7
Set jumper JP1, on the back of the thermostat, if you
have connected a wire to the G terminal.
Incorrect jumper setting: An incorrect setting is
noticeable in a gas or oil heating system. When heating
starts, you will initially feel cold air coming out of the vents
as the fan is running before the furnace has enough time
to heat up the air.
?? Set Heating Fan Control 6.
HG Leave the jumper in this factory-set
position if you have a gas or oil furnace.
HE Place the jumper to this position if you
have an electric furnace.
JP1
8
Set jumper JP2, on the back of the thermostat, if you
have a heat pump.
Incorrect jumper setting: The heat pump operation
will be reversed, i.e., it will cool in Heat mode and will
heat in Cool mode.
?? Set Heat Pump Reversing Valve 7.
O Leave the jumper in this factory-set
position if you have connected O wire to
the O/B terminal.
B Place the jumper to this position if you
have connected B wire to the O/B terminal.
JP2
9
1) Install 2 AAA
batteries on the
back of the
thermostat.
2) Align the two
brackets on the
top of the
thermostat with
the corresponding
slots on the top of
the wallplate.
3) Push the
thermostat
against the
wallplate.
4) Tighten the screw
at the bottom of
the thermostat.
5) Turn power back
on at the heating/
cooling system.
