Have Motorola droid XT 912 I replaced the battery but is working now but it's just showing like a? On the inside the batteries sign of you I have an answer please let me know
You should confirm that any battery you purchase has a "Motorola Original" hologram.
If you see a message on your display such as Invalid Battery or Unable to Charge,
take the following steps:
• Remove the battery and inspect it to confirm that it has a "Motorola Original" hologram;
• If there is no hologram, the battery is not a Motorola battery;
• If there is a hologram, replace the battery and try charging it again;
• If the message remains, contact a Motorola authorized service center.
SOURCE: motorola w220 invalid battery problem
you better change the battery and dont recharge too. charge daily per hour
SOURCE: My droid screen suddenly turned
You might want to try a hard reset on the phone, it should put your phone back to normal if its a software issue, if its a hardware issue you might have to take the phone apart or send it in for repairs or warranty return.
You can hard reset your Motorola Droid if you want clear all of the data off of the device and start fresh. Here’s how it’s done.
1. Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
2. Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appers.
3. Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
4. Use the direction pad to the right of the keyboard to select the Format option.
SOURCE: when making a call or
I had the same problem.
If your battery is not a Original Nokia (Genuine) Battery,then you must replace it with a genuine Nokia battery.
If the problem remains,then you have to Reset your phone
How to do it :
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.(Read Method 3)
or try this(But it will fully format your phone)
Method 1:
Three Finger Reset for Nokia Phone
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
Hard Format of Nokia Mobile Phone
2. Now Press following key-*#7370#
3. Enter Default lock code is 12345.
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Soft Reset of Nokia Mobile Phone
1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
