Question about Food Mixers
Cooks stand mixer modes SM 248. The mixer starts out at a very high speed when mixing. Have tried the reset button to no avail. Help
Posted by Bonnie... on
Owen Shaw
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Check cords that lead to the switch and mixer.
If find nothing unusual, replace the switch.
Posted on Oct 24, 2013
5 Related Answers
gramkat
SOURCE: sunbeam mixer
When you open it, there is are contact points and a piece that has to touch to change the speed. It may just be slightly bent or out of place. Some food may have gotten in there.
Posted on Jun 05, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: blade won't release from mixer
To Remove Flat Beater, Wire Whip or Dough Hook
1.
Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft.
If the beaters are stored on the shaft of the mixer when not in use, food traces can harden and make mixer attachments difficult to remove. Should this occur, wrap a hot, damp towel around the shaft to heat and expand the area. A small amount of cooking oil sprayed around the shaft may also help. After the beater has been removed, thoroughly clean the beater shaft area with a small brush to remove any food residue.
-Tha Mp3 Doctor
Posted on Dec 30, 2008
Anonymous
  • 16 Answers
SOURCE: My Kitchenaid K5SS 300 watt standing mixer launches into the highest speed regardless of the speed ....
I would recommend that you first check the Hall effect sensor which determines the speed.  I had this exact problem (but mine occurred with a 600 professional model) and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My blender worked as good as new! But I was curious to know if my original sensor was defective so I put it back in mixer and again made sure all of the connections were tight.  Guess what?  My original sensor also made my mixer work!  There was nothing wrong with my original Hall effect sensor except the connection between the control board and sensor was not adequate--unfortunately I didn't check the connections before I decided to buy another one. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. 2.  You'll need a phillips head screwdriver to open up the mixer. 3.  Make sure that the connection between the control board and sensor is absolutely tight and snug. 4.  Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work.  Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it.  I actually found the right orientation through trial and error.  By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work it were reconnected with correct orientation.   5.  This whole process probably takes less than 10-15 minutes to perform.
David Shaub
  • 2976 Answers
SOURCE: have a sunbeam heritage stand mixer model 2346-000.
Make sure the bowl is off to the side. I wouldn't get rid of a mixer just because the bowl doest't, if it's a good powerful mixer. There aren't many replacement parts available except directly from sunbeam. You need to get a replacement motor for the bowl turntable.
Posted on Jan 08, 2009
Bob Hewitt
  • 130 Answers
SOURCE: mixer head loose
Referring to the diagram on:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
Remove the screw, item 22, to remove the trim band around the mixer. This will reveal 4 screws which hold the top cover on. Remove the screws and lift the top off. Find all the screws which hold the gearhead in place and tighten them all. If you want to make the fix a permanent one put some thread-loc compound on each screw and tighten it.
Posted on Mar 30, 2010
Owner manual for Cooks stand mixer model #SM248
this page says it has it, but I am a bit concerned that it is a zip file
Download cooks stand mixer owners manual ' Diigo Groups
https://groups.diigo.com/.../download-cooks-stand-mixer-owners-manual-6694925stand mixer Model SM248, 700 watt, 12 speed, 5 qt http://retrorenovation.com/wp-content/gallery/1960-drexel-catalog/drexel-profile-18.JPG Documentation Location Service: Reference Information Report for KitchenAid Classic Stand Mixer KSM5 Service Manual cooks stand mixer owners manual. Service manual for the ...
Cooks stand mixer model SM248 manual Google Search
Feb 14, 2018 | Food Mixers
Will kitchen aid attachments such as grinder or shredder work on my cooks sm 248 mixer
contact the manufacturer and see what attachments will work on your machine
If they are not the same brand as your machine , I doubt that they will
Apr 14, 2015 | Food Mixers
KitchenAid mixer speed surges high and low uncontrolably
You can get the high speed back if you want to play with those three screws. there is a timing scheme for your mixer and it is set and adjusted by manipulating those 3 screws. The bottom center screw is for speeds 6 8 and 10. The best choice is to replace this switch, about $10 bucks on ebay.
Nov 13, 2012 | KitchenAid K45SS Classic Stand Mixer
My kg25h7x varies the mixing speed on its own
The Kitchenaid uses a centrifugal switch to maintain a constant speed. This must be sticking to cause this. You mixer will need to be disassembled and inspected.
Jul 03, 2012 | KitchenAid K45SS Classic Stand Mixer
Cooks model sm 248 mixing parts and break down on parts along with owners manual or opereting manual
i have searched the web and cannot find a instructions Manual for the Cooks mixer Model sm248... any help?
Nov 13, 2011 | Cook's Essentials 700 Watts CESM100 Pro...
My cuisinart 5.5 stand mixer when you press the on button it starts for a second then it stops.
Make sure the plug is securely plugged into the wall.
Next, remove and reattach any mixing arms etc that may be attached to the mixer. Having one not attached properly can result in a start, start.
If problem persistes make sure the speed is reset.
If problem continues, here is an excerpt from the user manual found here.
http://www.cuisinart.com/share/pdf/manuals/sm-55.pdf
Problem: Your stand mixer has an
overload protection device and if
overloaded, it will shut down to protect
the motor.
Solution: In the unlikely even that this
happens:
• Turn off and unplug the unit.
• Reduce the load by removing some of
the ingredients, and allow the mixer to
stand for a few minutes.
Plug in and reset the speed. If the
stand mixer does not start when you
press the on button, allow the unit to
stand for additional time.
If you are still having trouble, the product comes with a 3 year limited warranty, so if you're bought it within the last 3 years it may be covered.
Good Luck!
Mar 01, 2011 | Cuisinart SM-55 Stand Mixer
When I turn on my Kitchenaid mixer at any speed, it ramps up to high speed and then shuts down after maybe 30 seconds.
You need a reputable repairman. My gears were stripped after trying to mix a very thick dough. It would only work on high speed. After it was repaired.... I still use it, all the speeds work, and that has been 15 years ago. My mixer was at least 8 years old at the time of the "stripping".
Aug 21, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The latch/switch on the speed control board is stuck
You need to take the back cover off and then split the gear cases to find the mechanical reason why the lever is stuck. Take the motor off the pedestal, remove the planetary and undo the 9 screws that hold the bottom gearcase to the top housing. You will need to unplug the white and the black wires from one side of the speed control plate.
Jun 14, 2017 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
249 people viewed this question
Top Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
john h
Are you a Food Mixer Expert? Answer questions, earn points and help others
