Kohler 12 kW Emergency Power System - 12RES-L Logo
brian maffei Posted on Apr 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Generator quit working
It is actually a kohler 5000 watt confidant rv generator. The generator quit running. The motor did not have any knocks and the generator was putting out voltage before it quit. It was misfiring just before it stopped running. I believe the problem is in the ignition system but I am not sure. The generator has 1944 hours on it and has some minor oil leaks. Is it better just to buy a new one or attempt to fix it. How much would it cost?
  • brian maffei May 03, 2009
    Thanks for nothing that was a useless solution
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 09, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1234
Points
I have fixed Dozens of generators and around 70-80% of starting- none running problems are due to either A) Debris soil dust or Water in the Carb (don't ask me where it comes from but it gets through or B) Jets blocked with same or just Electrolytic Crud, dissimilar metals Brass Jet in Allot Carb etc. First step drain tank & carburettor bowl (screw or bolt in bottom usually, run a needle or similar though the main jet (up in centre in Honda type designs) when sure all is clear, fit a $1-$2 small paper in-line fuel filter and try again. The standard filters are too coarse and let in fine dust-rust all the time, hope this helps always works for me, Good Luck from England!
Anonymous
Level 2:
  • Expert 116 Answers
  • Posted on Apr 28, 2009
Anonymous
Expert
Level 2:
Answers
116
Questions
0
Helped
65343
Points
309
I used to work at a repair shop for kohler 98 bucks an hour to check it out. and for them to repair who knows?. i would do my best if not in a hurry to figure it out on my own. you can purchsae a service manual and stick with your basics; spark gas, and from there go deeper.
  • Anonymous May 03, 2009
    im sorry you found that usless but add up the charges is what i was implying. if its leaking has high hours and not running... this is a total judgement call on your half. need a dependable generator? business or just for home and hobby? i cant make that decision for you sorry again .
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
Kohler Confidant 4 puts out to much voltage
Are you running the gen and plugging in the RV at the same time? I assume it is wired right and you have a transfer switch? Are you saying the voltage is fine when the RV isn't plugged in?
1helpful
My rv air conditioner won't run on a 5000 watt generator, it pops the breaker on the generator. It is a 15,000 on a 1992 prower regal travel trailer
Most likely the air conditioner draws more power than the generator can supply. Check the current needed for the air conditioner in amps. It should be on a plate attached to the it. If the generator is a 5000 watt it can supply 5000 divided by the voltage required by the airconditioner. i.e. 240 (=20.8 amps) if you live in the UK or Ireland or 120 (41.6 amps) in most of the rest of the world. If it's a 12 Volt Airconditioner than you divide 5000 by 12 Note this is the absolute maximum that can be drawn and as power generally fluctuates will still probably cause the circuit breaker to trip. You should ideally be drawing no more than three quarters of the current available. If there are other appliances being run off the generator this again reduces the amount of current available.
1helpful
Kohler Confident 7 model 7CCKM22 generator
sounds like a relay should be latching one it has started
1helpful
2answers
I have a 6500 lp onan marquis generator in my rv. It starts then stops after 15 seconds or so. I did a code check on it using the manual and it read code 47. Controller not reading generator running. Any...
ONANS ARE PRETTY QUIRKY AS IT IS NOT CONSUMER FRIENDLY. THE GENSET IS DESIGNED FOR ROUTINE AND SIMPLE MAINTENANCE PERFORMED BY THE OWNER, AFTER THAT, U WILL NEED TO TAKE IT TO THE NEAREST DEALER OR CUMMINS DIESEL REPAIR SHOP.
1helpful
2answers
Kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
