Question about Vitamix 5000 Work Top Blender
I have a vitamix VM0109 and the part that the
I have a vitamix VM0109 and the part that the drive socket fits onto has sheered off, is it possible to replace and if so where can i find the right part for it and instructions on how to replace.
Posted by marc on
  • Ash43
    Ash43 May 02, 2019
    Did you figure out any solution? I believe I have the same problem but cant find any information anywhere. It seems like a waste to have to buy a whole new motor when its just the gear on top that is messed up.
William Painter
    New Friend:
Check my viideo on vitamix sprocket repare https://youtu.be/Dq-kDO6H6N4?list=PLHtEamyrXElkiax86_fZYWR5UmgmevL2_
Posted on May 21, 2016
Ross Keen
  • Vitamix Master
  • 1,364 Answers
Drive socket meaning the clutch drive on top of the motor? If the shaft that part fits onto has sheared off then prepare to empty your wallet because that is the motor.
Posted on Dec 05, 2013
Where can I buy a clutch for a vita mix 5000
Shop for buy a clutch for a vitamix... on Google
Amazon.com: Vitamix Drive Socket Kit: Electric Countertop ...
www.amazon.com/Vitamix-891.../B0028Y4CVE
Amazon.com, Inc.
Rating: 4.7 - ‎249 reviews
Shop Vitamix at the Amazon Small Appliance Parts & Accessories store. ... blender on the fritz, PLEASE do yourself a favor and check the old drive socket before buying a whole new blender. .... This fitted perfectly into my vitamix super 5000.
Vita-Mix Parts: OEM Replacement Parts ' Parts Town
Dec 03, 2015 | Vitamix Vita Mix 891 - 1-Drive Socket Kit...
Where can I get a manual for the said Vitamix?
Go here to download it as a PDf file. The 5200 is what I think is most similar to yours.
https://www.vitamix.com/Owners-Resources/Product-Support/Owners-Manuals
Jun 15, 2015 | Vitamix Blenders
I have a Vita-Mix blender that is not performing right. Sounds like gear may be striped or slipping in and out of engagement. What can I do?
You may well find a small appliance repairer (not aligned to the manufacturer) locally who will take a look; alternatively, why not risk stripping it out yourself and taking a look?
Jan 26, 2015 | Vitamix Blenders
Drive socket
you can check this out, maybe what you're looking for?
Amazon com vitamix wrench assembly Home Kitchen
Feb 19, 2014 | Vitamix Blenders
Replace ball bearing
Part of the blade assembly or drive socket assembly?...
check here:
Jan 30, 2014 | Vitamix Blenders
I have a vitamix VM0109 and the spindle that the drive socket attaches to has sheered off, is it possible to replace it, if so where can i get the part from, whats the part number and where can i find...
Oct 23, 2013 | Vitamix 5000 Work Top Blender
Vm0109 Vitamix
Your local Vitamix service agent will be able to order one in for you.
Sep 30, 2013 | Vitamix Super 5000 Work Top Blender
Can't unscrew drive socket on vitamix super 5000 to replace it. The 5/64 hex wrench does not fit in. And another problem is that variable speed does not function. It is possible only slow or high speed.
The hex wrench only fits in one position, there is a groove in the lip in the top housing and you need to turn the coupling until the hex screw head lines up. The groove is normally plugged with a dob of white silicone. The hex screw is not tightened fully tight on reassembly, the coupling needs a bit of slop. Speed control problem will likely involve replacing the control switch assembly.
Aug 25, 2013 | Vitamix 5000 Work Top Blender
The piece thaat makes my vitamix turn fell off
Sounds like your drive socket broke. Use a small allen wrench to loosen set screw under arrow on drive socket. You will have to order a new socket from Vitamix. Hope this helps.
Apr 29, 2012 | Vitamix 5000 Work Top Blender
Sounds like gears are slipping and blades stop turning. no obvious damage to drive socket or gear on end of blade shaft.cant remove drive socket any suggestions on removal? Blade assy fits very loosly into...
First thing is to find the small hole on the plastic piece below the drive socket and remove the silicone in from it. Next turn the drive socket until the little arrow on the drive socket lines up with the hole, then look thru the hole to see the allen wrench screw in there loosen screw to remove drive socket.
Sep 15, 2011 | Vitamix 5000 Work Top Blender
Vitamix 5000 Work Top Blender Logo
601 people viewed this question
Top Vitamix Blenders Experts
Marvin
Marvin
Ross Keen
Lawrence Oravetz
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
