SOURCE: Beverage-Air DD50 Commercial Keg Fridge Not Cooling
The starting components on the compressor could be going bad. You need to turn off the thermostat and then after about five minutes turn it on while listening to the compressor to hear if it kicks in, if it doesn't then you might have faulty starting component, more likely the overload.
SOURCE: Will not cool. Fan runs, have cleaned coil.
The compressor may not be starting. Put your forehead against the nmachine when youturn it on or plug it in, You will feel the vibration of the pump. If it is not coming on, you may need a technician to what determine why it is not working.
SOURCE: Find locate of lighting ballast in 3 door BevAir cooler
Sometimes they are in the overheade space above the cooler .. if they were inside then they would have to be HO ballasts because of the temperature .. sometimes they are in the moulding strip under the lamp itself.
SOURCE: Beverage-Air KF48-1AS not coooling, fans not running
http://www.beverage-air.com/uploadedFiles/docs/CFG_CRG_KF_Series809-046A.pdf
go to this web site and get your manual. check it out and if you have any questions, drop me a line
