Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
We have a 2003 Frigidare professional series smooth cooktop range. The other day the front right burner would not shutoff. Tried turning off the breaker and unplugged the range with no luck. After the range sat for a day unplugged I tried it and the burner and control acted correctly? The range does show a code of F-7 sometimes when operating the control knobs? Any suggestions?
Posted by Paul Vincent on
1 Related Answer
Anonymous
SOURCE: frigidaire ceramic cooktop burner turned on by itself
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
NEED TO REMOVE RANGE TOP. THE LARGEST BURNER NUT HOLDING THE VENTURI IS STUCK. OTHER THREE BURNERS REMOVED OK. DO I HAVE TO SPLIT THE VENTURI NUT TO REMOVE RANGE TOP? I NEED TO GET INSIDE RANGE UNIT.
Yes keep playing with it and BOOOOM! Call in a professional. This is the law with gas appliances.
And turn off the CAPS lock. We heard you the first time :-)
Jan 24, 2016 | DCS "CTD-304-L 30"" Drop - in Cooktop, 4...
Cooktop cracked suddenly just after cooking
Not exactly "safe" to use. If I remember right in my travels, Algona Iowa had a used and vintage appliance parts store. I am sure there are plenty of others out there but I know they exist.
Nov 14, 2015 | Kitchen Ranges
All valves off but igniters keep clicking.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 08, 2010 | Frigidare PLGC36S9EC 36 in. Portable Gas...
Large electric burner will not turn on
you need to check the wiring to that burner it appears that there has been a short to the burner
Apr 04, 2010 | Jenn-Air 35 in. JEC9536ADS Electric...
Frigidaire ceramic cooktop burner turned on by itself
Hope this helps.
Jan 28, 2009 | Frigidaire FEF366DC Electric Kitchen Range
How do you replace a burner switch on a Frigedaire Glasstop Stove
The repair on this stove will be relatively easy then. All you are going to have to do is pull out the stove from the wall and remove the upper part of the back panel where the burner switches are.
Remove the knob and take out the screws that hold the switch to that front panel. Then from there just match up the wires to the new switch off the old one.
This repair will turn out to be pretty cut and dry for you. If you have anymore questions please ask.
Thanks Again,
Bill
Jan 10, 2009 | Frigidaire FEF366DC Electric Kitchen Range
SMOOTH COOKTOP DISCOLORATION
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff really works!!
Aug 12, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Burner will not turn off
You'll need to replace the burner switch. This happens when the contacts become fused together.
Mar 24, 2008 | Frigidaire FEF366DC Electric Kitchen Range
Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Oct 14, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
70 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
