D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
Posted on Apr 26, 2009
I have a d-link wbr-1310 ver:d1 f/w:4.00 no signal
I have a d-link wbr-1310 ver:d1 f/w:4.00 I get power but I do not get any signal from a wired or wireless. If any one out there has a fix or an idea on how to fix this problem please right back.
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Apr 27, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
Helped
9177
Points
42
Reset your router wait 20 sec re-boot
go to your wirless pc / or lap top and see if you can see this product
if not you may issues that can not be fixed remotly
I have a D-Link WBR-1310 router, that I need to set up on my new computer, but I have misplaced by Install CD, How do I set the router up
Go to http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
and select the data you want. The software is down loadable. make sure that your router is not a B or C version as the one shown is just for the WBR-1310. It also has setup instructions if you want to learn to do it your self rather than default to setup software.
Lap top WI-FI does not work with this WBR-1310...no signal showing connections...however, did work a few days ago. Using HP laptop Pavilion.
Make sure you didn't accidentally hit or tap the wireless button as that shuts off all internet connecting abilities.
1helpful
2answers
My WBR-1310 doesn't do wireless to my laptop.
theres a couple of version of this router http://www.dlink.com/products/default.aspx?pid=WBR-1310&tab=3 I'm using the manual from here http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
on a working PC download and install this program http://www.xirrus.com/library/wifitools.php this will detect all the wireless signals being broadcast - see if the router is actually broadcasting - if it is detected on your PC then it may be that 1) the firewall is blocking access or 2) the security code is entered wrong - -log into the router and remove the wireless security and see if you can now detect
1helpful
I HAVE A DLINK WBR-1310 ROUTER WHERE DOES THE BLUW
Hi!
You can use any UTP cables. Here is how the connection would look like:
DSL -> DLINK WAN PORT
DLINK PORT 1(or any other ports) <---> COMPUTER
If the router is set to give out IP addresses automatically(DHCP), you should be able to connect flawlessly.
D-Link Wireless Router WBR-1310 wont connect?
- Check LAN cable
- Use a different cable
- Use "crossed" LAN cable
I have a D-Link/WBR-1310 wireless router. I
the manual can be found online
depending on your revision of the router click on the links to download the manual
WBR-1310
ftp://ftp.dlink.com/Gateway/wbr1310/Manual/wbr1310_manual_110.zip
WBR-1310_REVB
ftp://ftp.dlink.com/Gateway/wbr1310_revB/Manual/wbr1310_revB_manual_220.zip
WBR-1310_REVD
to check which revision you have see this
q_detail.jpg Where do I locate the serial number (SN), hardware version/revision information (HW ver), MAC address and model number? a_detail.jpg The serial number, hardware version/revision information, MAC address and model number, will be located on a label on both the outer box, and on the adapter itself, usually attached to the bottom of the unit.
Connection
Go to this site to download a manual to verify you have it setup right.
http://www.d-link.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
or try this first.
Power off your modem,D-Link and PC.
You need to have the cable that looks like a wide phone plug with 8 contacts instead of 4 (cat 5 cable) go from your comcast modem to the plug on back of the D-Link that is marked WAN.
Then plug a cat 5 cable into any of the 1 through 4 Lan ports on back of the D-Link to your PC's Ethernet port.
Then with all these powered off turn on the Comcast modem, wait a full 2 minutes for it to settle in. then turn on the D-Link give it 2 minutes then turn on your PC.
If that doesn't work for you refer to the manual or you have something broke that may require servicing in person by someone computer savvy.
Hope this helps.
2answers
3helpful
Free download of d-link wbr-1310
just click below link and select your country code you can download
the installation guide for free
http://support.dlink.com/products/revision.asp
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
