Question about Sharp Televison & Video
I need a Sharp GA867WJSA LCD TV Remote Control
Posted by tarek fouad on
    Top Expert:
  • Sharp Master
  • 76,407 Answers
To select a remote control, you have to know about the setup codes to Sharp Brand TVs. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Check these links, and find out which remote control have setup codes to Sharp Brand TVs, in code list, and buy that brand remote control according to availability.
Brand name of the remote control isn't a matter, but, it should have setup codes to Sharp Brand TVs.
Posted on Oct 23, 2013
5 Related Answers
Anonymous
SOURCE: universal remote
need a code for a philips remote to control a zenith tz
Posted on Dec 27, 2007
Anonymous
  • 97 Answers
SOURCE: Universal Remote control code on Sharp 13H-M60
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 20, 2008
jeffrey gallagher
  • 42 Answers
SOURCE: Sharp Remote Control Problem
trying removing the batteries and reinstalling then the reset the remote and then tell me if it works if you have lock the parental function on sould like
Posted on Jan 04, 2009
Anonymous
  • 5 Answers
SOURCE: i need the code for my sharp tv so i can program my rca remote co
After much searching I finally found the code list for RCR451 Universal Remote. Here are the codes for Sharp TV. 1004, 1007, 1009, 1023, 1078, 1083, 1094, 1107, 1123, 1125, 1195
Posted on Jan 14, 2009
Anonymous
  • 170 Answers
SOURCE: I need programming instructions for Jensen Remote
Here you go...it took a while but I found the user manual cause I ROCK....that's right say it with me....He...Rocks...hehe...but anyway here is the link address if the link doesn't work...
http://safemanuals.com/user-guide-instructions-owner-manual/JENSEN/JER-321-_E
I hope this helps...good luck and thanks for rating my effort....the Fang
Download the completeuser guide (3257 Ko)
Posted on May 20, 2009
How can i program this remote to a sanyo tv remote is a sharp GA447SA
You can't. Each make is proprietary to its own make and they are not programmable.
Google
Sanyo <model> replacement remote
You will find replacements for that particular set on eBay, Amazon and specialist remote outlets.
Sanyo OEM & Replacement Remotes - Remotes.com‎
Adwww.remotes.com/‎+1 800-736-6837 Buy Any Replacement Remote Control! Order Online or Call 1-800-Remotes
Brands: Samsung, Panasonic, Philips, Toshiba, Magnavox, Yamaha, Sharp, RCA, JVC, Pioneer
Search Results
SANYO TV Remote Controls ' SANYO Replacement Remotes for TV ...
https://www.replacementremotes.com/SANYO/Remote-Controls/ ReplacementRemotes.com offers SANYO remote controls for sale online including remote controls for TV, Projector, VCR and many more.
Amazon.com: Sanyo - Remote Controls / Remote Controls ...
https://www.amazon.com/Remote-Controls-Sanyo.../s?ie=UTF8...1...4%3ASanyo Results 1 - 24 of 146 - Factory Original SANYO RC200NS00 LCD / LED HD TV Remote Control For Sanyo HDTV Television (8TL06-530W37/ 8TL06530W37). by Sanyo .... Generic Replacement Sanyo LCD Hdtv Tv Remote Control Gxbc Gxab Gxbj Gxbd Ht32546 Dp50747 Dp26649 Dp42746 All Sanyo Led Lcd Plasma Tv.
Amazon.com: Remote Control Replacement For Sanyo DP42841 ...
https://www.amazon.com/Remote-Control-Replacement-DP42841.../B00J7S2P7W Rating: 4.1 - ‎8 reviews
Factory Original SANYO RC200NS00 LCD / LED HD TV Remote Control For Sanyo HDTV Television.... ... Sanyo LCD Plasma HDTV TV Remote Control GXBM Supplied with models: DP32640 DP42740.... ... TV Replacement Remote Control For VIZIO VW32L VW42LHDTV10A E420-A0 LCD LED PLASMA....
SANYO TV Remote Controls ' eBay
https://www.ebay.com > ... > SANYO TV Remote Controls Results 1 - 48 of 104356 - Replacement Remote Control for ROKU 1/ 2/ 3/ 4 LT HD XD XS Streaming Player with 4 Shortcut Buttons (Do NOT Support Roku Streaming Stick, Hdmi Stick, Roku TV and Game). - ROKU 3 (Note, this remote DOES NOT have a headphone jack or pair button but it works like a charm with ROKU 3).
Universal Replacement Remote Control Fit For Sanyo DS13530 ...
https://www.amazon.ca/Universal-Replacement-Control-DS13530.../B00MGHAPRS Universal Replacement Remote Control Fit For Sanyo DS13530 DS13630 DS19650 DS19730 DS20380 LCD LED PLASMA HDTV TV: Amazon.ca: Electronics.
Universal Replacement Remote Control Fit For Sanyo GXCF ...
https://www.amazon.ca/Universal-Replacement-Control-DP19640.../B00HH5SFQM Universal Replacement Remote Control Fit For Sanyo GXCF DP19640 GXCC DP26649 LCD LED Plasma HDTV TV: Amazon.ca: Electronics.
Sanyo Remote Controls - Walmart
https://www.walmart.com/c/brand/sanyo-remote-controls Original Sanyo GXBA / 6450750984 Remote Control TV Television Projector DVD. This product is compatible with the following model numbers: GXBA, 6450750984, DS24425, DS24425, DS27225, DS27225, DS27425, DS27425, DS32225, DS32225. This product comes with a warranty of 1 Year. Product - Original Sanyo ...
Sanyo TV Remote Control New OEM Replacement Remotes
www.sanyo.newremotecontrol.com/SanyoTV.php Model Number, Remote ID Number, Remote Part Number. AVL-191, RC-Q32M-0A, XI6010Q03201. AVL-193, RC-Q32M-0A, XI6010Q03201. AVL-209, RC-Q32M-0A, XI6010Q03201. AVL-408, RC-U46R-0A, 301-UP42K8-46RA. AVL-428, RC-U46R-0A, 301-UP42K8-46RA. AVM-1304, FXBA, 6450001291. AVM-1904 ...
Apr 03, 2018 | Sharp Televison & Video
I forgot the password for my sharp lcd tv GA867WJSA. PLus i don't even have the manual. What do i do?
Check these codes. 083,019,065,029,000. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 14, 2013 | Televison & Video
Need remote for sharp aquos LC42XD1E
Setup codes to Sharp brand TVs with universal remote control are 0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122. Just buy a remote control, which has setup codes to Sharp TV. You can get this iformation from the attached specification sheet with each universal remote control If you wish to get more details to different other brand remote controls, check this link.
Feb 06, 2013 | Sharp Aquos LC42XD1E 42 in. LCD TV
GA867WJSA
If the audio level is set so by the company, you can't cheange it.
Apr 23, 2012 | Sharp Televison & Video
Lost access to control SHARP TV
Unplug your unit and plug it back in after 2 minutes. When you plug it back in, try to use the remote to turn it on and see what happens. Good luck to you
Apr 07, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Need codes for on for all universal remote.
i have a sharp 42" lcd tv and i need the remote code for the time warner scientific atlanta new york city cable box on the sharp remote
Nov 21, 2008 | Sharp RRMCG1687PESA Remote Control
Remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Oct 21, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Code for sky+ remote cotrol
If you mean you want to program the remote to control your sharp tv, here is the list of sharp codes:
0093, 121, 121, 064, 065, 081, 322, 122, 185
Mar 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
555 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
