Minolta bizhub 200 All-In-One Printer Logo
A
Anonymous Posted on Oct 23, 2013
C222 c0202 - Minolta bizhub 200 All-In-One Printer
Norman Weimar
Level 3:
  • Minolta Master 7,035 Answers
  • Posted on Jan 23, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7035
Questions
Helped
1913110
Points
11959
Remove the first draw check for paper behind it. Then remove the paper that is stored on the left hand side . That is not a storage area its for when you want 11x17 paper placed in the draw. If that does not clear the code the motor or the sensors that monitor the tray are bad or worse the control board is bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How do i resolve the issue of Konica Minolta Error Code C0202?
The error code C0202 indicates paper jamming in tray 1, C-O204: Tray-2, C-0206: Tray-3, C-0208: Tray-4. First of all, power off and unplug your copier, then empty paper from the problem tray and from the tray below it. Take out the problem tray, now you can see a paper jammed.
how to fix trouble code C-0202 error code in Konica Minolta ...
Videos as well
https://www.google.com/search?q=Konica+Minolta+Error+Code+C0202
Konica printer error code c0202
try to reinstall the printer driver
2009 chevy impala left front side deployment loop resistance B0014 above threshold
the following link covers yours reqest The driver frontal loops 1 and 2 are the loops to the steering wheel air bag. The SDM(sensing and diagnostic module for the air bag) is seeing these circuits as open. There is a bullitin for problems with a loose connection for the yellow connector behind the left kick panel(right behind the e brake and hood release). I would remove the kick panel, and disconnect and reconnect the connector a couple times. See if the light goes out. Or wiggle and move the connector with the key on, as the light should go out if it makes good connection. If it does go out you need to replace this connector. Good luck.
#05-09-41-001B: Supplemental Inflatable Restraint (SIR) Light ON, Diagnostic Trouble Codes (Inspect/Replace IP Harness to Inflatable Restraint Module (Air Bag) Yellow 4-Way Connector C221 and/or C222) - (Jun 2, 2008)
Subject:Supplemental Inflatable Restraint (SIR) Light ON, Diagnostic Trouble Codes (DTC) B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044 (Inspect and/or Replace IP Harness to Inflatable Restraint Module (Air Bag) Yellow 4-Way Connector C221 and/or C222)
Models:2003-2006 Cadillac Escalade Models
2003-2006 Chevrolet Avalanche, Suburban, Tahoe
2003-2007 Chevrolet Silverado (Classic Only)
2003-2006 GMC Yukon, Yukon XL, Yukon Denali, Yukon Denali XL
2003-2007 GMC Sierra (Classic Only)
This bulletin is being revised to add the 2007 model year for pickups and change a part number. Please discard Corporate Bulletin Number 05-09-41-001A (Section 09 -- Restraints).
<A href="#ss1-2146754">
Condition
Some customers may comment that the Service Supplemental Inflatable Restraint Light is on.
Diagnosis with a scan tool may indicate a DTC B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044.
<A href="#ss2-2146754">
Cause
The most likely cause of any one of the following DTCs: B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044 is improper connection/high resistance in the IP harness to inflatable restraint module connector C221 and/or C222.
<A href="#ss3-2146754">
Diagnostic Information
DTC B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044 will set when one of the following conditions occur:
• The SDM detects the air bag module deployment loop resistance is greater than 4.8 ohms for 500 milliseconds.
• The SDM detects that the voltage at the air bag module high control is less than 2.4 volts and deployment loop resistance is 6 ohms or greater for 500 milliseconds.
• For additional diagnostic information, refer to DTC B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044 in the appropriate SI Document.
<A href="#ss4-2146754">
Correction
DO THIS
Don't Do This
Test for proper connection/high resistance at connector C221 and/or C222.
DO NOT replace SIR system components prior to testing for proper connection/high resistance in C221 and/or for DTCs B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044.
Caution: When performing service on or near the SIR components or the SIR wiring, the SIR system must be disabled. Refer to SIR Disabling and Enabling Zones. Failure to observe the correct procedure could cause deployment of the SIR components, personal injury, or unnecessary SIR system repairs.
Important:
The IP harness to inflatable restraint module connectors C221 or C222 is NOT located at the base of the steering column.
• C221 (4 Cavities) -- I/P Harness to Body Harness, behind the left kick panel
• C222 (4 Cavities) (w/o HP2) -- I/P harness to body harness, behind the right kick panel
• C222 (4 Cavities) (w/HP2) -- Behind the left side I/P access panel
• Refer to the Master Electrical Component List for additional location information.
  • <LI type=1>Remove the appropriate side door sill plate. <LI type=1>Remove the appropriate side hinge pillar panel. <LI type=1>Locate the IP harness to inflatable restraint module yellow 4-way connector C221 or C222. <LI type=1>Inspect the IP harness to inflatable restraint module connector C221 or C222 for proper connection. <LI type=1>Disconnect and reconnect the IP harness to inflatable restraint module connector C221 or C222 THREE times. <LI type=1>Clear the DTC and road test the vehicle. • If DTCs B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044 DOES NOT reset, no additional repairs are necessary. Continue with step 10.
    • If DTCs B0013, B0014, B0017, B0018, B0024, B0026, B0043, B0044 DOES reset, the most likely cause is high resistance in the IP harness to inflatable restraint module connector C221 or C222. Continue with the next step.
    <LI type=1>Replace the appropriate connector C221 and/or C222, P/N's 15306186 and 88987998. Refer to SIR/SRS Wiring Repairs (SI Document ID #325229). <LI type=1>Road test the vehicle and confirm that the repair is complete. <LI type=1>Install the driver's side hinge pillar panel.
  • Install the driver's side door sill plate.
<A href="#ss5-2146754">
Parts Information
Part Number
Description
Qty
15306186
Connector (4-way Female, w/Leads)
Connector (4-way Male, w/Leads)
1 Service Airbag Have Codes Ask the GM Technician
9helpful
Error code c0202
c0202 means that the top paper tray is not rising to bring the paper in contact with the feed rollers. Remove all of the paper from the tray and try turning the machine off and on with the paper tray not pushed in to the machine. Good luck.
1helpful
A paper jam was not cleared in a timely manner, now the machine will only display "Error Code C0202, Call Technician" It is Saturday and I can not get a hold of anyone at our support center. How can I...
C0202= tray 1 elevator failure.
Open tray 1, check and make sure paper is loaded correctly.
With tray open, open and close front door. This will reset error code. With tray 1 open look to see if paper is stuck behind tray in back of machine, if so remove it ( this will block the lift motor for the tray).
Close tray 1, if you hear a popping noise the lift motor is damaged and will have to be replaced. Until it is replaced operate machine with tray 1 out to prevent error code.
12helpful
CODE B0026 HOW DO I RESOLVE? REAR DOOR LOCKS NOT WORKING, SERVICE BRAKE BOOSTER WARNING ON, AIRBAG LIGHT ON, SERVICE AIRBAG WIRNING, INTERMIT NO START. HELP MEEEE!!!!!!
The airbag connectors in behind the front kick panels have high resistance. The fix is to replace them. Here is TSB's
Subject:
Models:
Condition
Cause
Correction
DO THIS
Don't Do This
Important: The IP harness to inflatable restraint module connectors C221 or C222 is NOT located at the base of the steering column...
1. Remove the appropriate side door sill plate.
2. Remove the appropriate side hinge pillar panel.
3. Locate the IP harness to inflatable restraint module yellow 4-way connector C221 or C222.
4. Inspect the IP harness to inflatable restraint module connector C221 or C222 for proper connection.
5. Disconnect and reconnect the IP harness to inflatable restraint module connector C221 or C222 THREE times.
6. Clear the DTC and road test the vehicle.
7. Replace the appropriate connector C221 and/or C222, P/N's 15306186 and 88987998. Refer to SIR/SRS Wiring Repairs (SI Document ID #325229).
8. Road test the vehicle and confirm that the repair is complete.
9. Install the driver's side hinge pillar panel.
10. Install the driver's side door sill plate.
Parts Information
Part Number: 15306186
Description: Connector (4-way Female, w/Leads) - Qty 1
Part Number: 88987998
Description: Connector (4-way Male, w/Leads) - Qty 1
Hope this help (remember comment and rated this help).
9helpful
Error code C0202
this is a tray 1 lift up failure code pull the paper tray out and check to see if some torn paper is blocking the lift sensor look around where the paper is fed into the feed plates if not it could be a failed lift motor or sensor and they will need to be replaced
2answers
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
