Question about Electric Eyeware Toys
What do I do about the discomfort in my eye? I can barely keep them open at times. I experience twitching at other times. I tried using the eye drops that was prescribed to me the last time this happened. I spend a lot of time on the computer. That was one cause suggested by the doctor the last time. But this doesnt seem to go away. What should I do?
Posted by Lex Luther on
Kev Loftin
    New Friend:
The constant use of computers are the cause of eye problems for many a person these days. I had twitching troubles a while back. It has to do with the manner in which we use it. It is not recommended to stare at the monitor constantly without any break. Take short breaks in between long sessions of staring at the monitor. Rest your eyes frequently. Get adequate sleep. All these are basic tips that any optometrist would tell you. Don't try to self medicate. If it is a problem that is recurring, then best consult with an eye clinic before it gets worse.
Posted on Oct 25, 2013
My left eye keeps twitching
You may have a nervous tick but visit a doctor to rule out anything else
Nov 07, 2016 | Cars & Trucks
My left eye is twitching left to right. What causes that to happen?
caffine, stress... there's a ton of stuff. If it keeps twitching for an extended period of time, go see a doctor.
I couldn't figure out why my eye was twitching and then I realized that the Diet pepsi Max (with the tons of added caffine) for breakfast was probably doing it. Take a look at what you're eating and drinking.
Nov 23, 2010 | Health & Beauty
Hi there, i have a samsung t190 and it keeps twitching!
You can have intermittent open wires in the cable. Try new cable yet? Unless there are bad solder joints where the connector is. Or it can be something in the logic board.
http://s807.photobucket.com/home/budm/allalbums
May 10, 2010 | Samsung T190 19" Widescreen LCD Monitor
Try to check connectors including ribbon wire and try to trace some possible lose connection especially for with add on ckt. Try also to re-solder pins on hot area.
Mar 21, 2010 | Samsung T190 19" Widescreen LCD Monitor
SP MODE AND INSTALLATION PROCEDURE FOR TOSHIBA DP 1660.
Installation Procedure:
01.Open the machine and take out all tape
02. Open the front cover and right hand side cover + blue lock press and open the black part
03. front side two scrow (big) open
04. Out of PC Unit ( drum and developer Unit)
05. done you Two part the ( drum and developer Unit)
06. developer keep on developer
07. total Items set on the machine
08. main switch on
SP mode
01. 0+5 press and main twitch same time for AJ MODE
02. 0+5 press and main twitch same time for ADMODE
Jan 28, 2010 | Toshiba e-Studio163 Copier
Red-eye reduction in macro mode
The red-eye reduction feature causes the flash to blink on and off rapidly, then flash normally. This may cause over exposure and subject discomfort in the macro mode.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Toys Logo
138 people viewed this question
Top Electric Eyeware Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you an Electric Eyeware Toy Expert? Answer questions, earn points and help others
