Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
NO ICE IN MY BOTTOMFREEZER AMANA REFRIGERATOR
MY AMANA FRIG WITH A BOTTOM DRAWER FREEZER HAS A TRAY WHICH MAKES ICE .IT WONT MAKE ICE.THE BAR IS DOWN.WHAT CAN I DO?
Posted by MIMIINDEPEND on
John Tripp
  • Amana Master
  • 4,656 Answers
If we both are on the correct subject then it is possible the water control valve on back of refrigerator is not working. If ice tray is dry then fill with water from a cup and let freeze. If the ice maker dumps the ice let me know and we will go from there. Sea Breeze
Posted on Apr 26, 2009
The whirlpool I have is a side by side if have a bottom drawer freezer. And my ice maker is in there .my light switch stop working so I replaced it so now the light comes on when the drawer is open...
If no ice check to see if there is water in the tray. If no water in ice maker tray issue is with the fill solenoid. If water in tray the heater is no good and the ice scooper cannot move the ice from the tray to the bin. If you want you can just replace the ice maker on ebay for cheap
eBayeBay
Sep 23, 2017 | Whirlpool Refrigerators
Ice maker bar is broken. is there any way i can make it manually (aside from the traditional pour water in tray!)? or do i have to replace the entire bar/apparatus? thanks.
This website has the diagrams for the ice maker along with the parts listed. The bar is listed as #16 and $20 to replace while the icemaker is#17 and $117
Aug 31, 2013 | Amana ARB2257CSR Bottom Freezer...
Ice maker stopped working on bottom freezer amana. Is there a reset button?
There is n such reset button,but first check and confirm that water line is running in to the ice maker drawer.Is the water getting into icemaker or not.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Amana ARB2214C Bottom Freezer Refrigerator
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Too cold in frig
Check for a faulty thermostat it is responsable of shutting down the compressor when it reaches your desire temp.
Jan 19, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Leaking water
test: first, turn off water supply to frig. then dry up all water. then ensure frig is running at right temperature. now gradually turn on water and observe where leak is. My guess is it is overflowing the ice-maker. there is an adjustment for this. pop off the cover over the end of the ice-maker. look for a screw adjustment. turn it counterclockwise.
Jun 04, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
182 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
