Sony Ericsson Walkman W705 Cell Phone Logo
N
Naseem Posted on Oct 23, 2013
Hard reset How to restore factory settings apart from master reset all option
ADEGBITE ABBAS
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Oct 23, 2013
ADEGBITE ABBAS
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
730
Points
41
PRESS POWER BUTTON DOWN AND # KEY FOR 2 SECONDS
1 Related Answer
Anonymous
  • Posted on Feb 21, 2009
SOURCE: What is the master reset code for Sony Ericsson P990i
master resetcode for sonyericson P990i
Can I unlock Nokia 3510 without the phone number?
There are two types of lock.
A consumer set lock. The way to fix is to do a hard reset.
Method 2: Hard Reset/Factory Reset Using Master Reset Code (One)
  1. Step 1: Grab your Nokia 3510i.
  2. Step 2: Now, dial the code *2767*3855#.
  3. Step 3: After dialing the above code, you will see the option "Restore Factory Settings".
  4. Step 4: Simply, choose the option in order to start the factory resetting process.
More items...
How To Reset and Unlock Nokia 3510i
And a PUK Lock aka a SIM Lock
https://www.fixya.com/support/r26056685-phone_asking_puk_code
Securety code eror
check this one
Master Code Generator will Instantly generate your Nokia's Master security code.
This service can be used if you need to reset your Security Code.
Your IMEI: 356924034968264 --
Your Nokia Master Code: 2401254345
or this one
Nokia 5000 hard reset
You can format your Nokia 5000 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YESRestore factory settings
To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options:
Restore settings only - to reset all preference settings without deleting any personal data
Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys
IMPORTANT!
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings
goodluck
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
Formate nokia310
Please always Remember, while doing Master Reset Nokia Asha 311 to factory default, the data will be loose, that's why we can do backup all data or important stuff at Nokia Asha 311.
#Option 1, Hard Reset Nokia Asha 310 & 311 with menu setting:
  1. Make sure the Nokia Asha 311 on and standby
  2. Go to menu Setting, then choose restore factory setting > settings only
  3. It will ask security code, input default security code of Nokia Asha 311 : 12345
#Option 2, Hard Reset Nokia Asha 310 & 311 with special code / master key / shortcut / secret key :
  1. Try to type: *#7370# and it will ask the security code of Nokia Asha 311, press 12345
  2. You also can try type: *#7380#
#Option 3, Soft Reset Nokia Asha 310 & 311 with special key code :
Please take attention, this option is for soft reset, so Nokia Asha 311 will not removing any important data and installed applications. How soft reset Nokia Asha 311 work: It will recopy or restore the default copy of .ini to Nokia Asha 311.
  1. Type in the phone : *#7780#
1helpful
How can I reset my c905 to factory setup
Restore phone to factory default settings
Restoring your phone can be useful if you lend out the phone or just want to restore your phone to factory default settings and delete all user data.
To perform a master reset of settings and delete all settings and user data:
  1. Select Menu > Settings > General (tab) > Master reset.
  2. Select an option:
    • Reset settings: If you want to delete all user data, such as contacts, messages, and downloaded games.
    • Reset all: If you want to reset both user data and restore all original phone settings.
  3. Select Continue > Continue.
  4. The phone restarts.
Note: When making a factory reset of all content, you may lose content that was in the phone when you purchased it.
May 28, 2011 • Cell Phones
2answers
How can i reformat my motorola cingular v3xx?
The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to "Settings"
2. Next go to the selection for "Initial Setup"
3. Next go to the selection for "Master Clear"
4. Then select to confirm the option.
5. Now enter the security code which should be "000000"
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a "hard reset", "hard reboot", or "master reset" on your Motorola V3 RAZR and it should return to normal operating mode!
May 01, 2011 • Cell Phones
1helpful
4answers
To restore the factory setting
how to restor k300i factory settings
Mar 10, 2011 • Cell Phones
21helpful
2answers
Master reset code for nokia 7310 supernova
there are two method of doing hard format on most of the nokia devices.
1.manually
1. go to menu and search for setting option.
2.enter in setting menu and search for restore factory setting option.
3. when you press on restore factory setting it will ask you for code enter 12345 the default code.
now you are done.
2.USING CODE.
DIAL *#7370# on main screen.a menu will pop up like restoring all data press ok enter 12345 default code.you are done now.
TO RESTORE SETTINGS ONLY.
USE THE CODE *#7780#
always use fixya to fix every thing
Sir i forget my security code of my nokia5200. imei 358659/01/855277/9. sir plzzzz help me plzzz
Hello thanks for using fixya
Default security code for your nokia hand set is 12345
but If you forget the security code then by Master Code you can unlock your Phone. To get the master reset code. Click Here
Give your IMEI like your is
358659018552779 their. It will generate master code.
You can also get your master code from Here
If your phone is active & u have just forgotten your code and want to know it then better option is to
reset phone to factory settings
Type *#7780# or to hard reset type *#7370# & then press Yes to confirm initialization to reset set to factory settings. It will take some tome and set will be restore to factory settings, Now your security code will be default as 12345.
Note: Remember one things this will deletes all your messages, all contacts, photos, notes etc in the phone memory.Your phone is like a new phone. So better is first save all your data and then restore it
Anymore help i am here to help
I hope this solution will helpful 4 u
Please keep thumbs up in do Rating if it is helpful
THANKS & Keep Using fixya
C905
  1. Select Menu > Settings > General (tab) >Master reset.
    • Reset settings:If you want to delete all user data, such as contacts, messages, and downloaded games.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
