Question about Stihl Ts 510 760 Cut Off Saw Repair Manual
Gas oil mix - Stihl Ts 510 760 Cut Off Saw Repair Manual
chris l2
  • 46 Answers
50 parts fuel to 1 part oil.
Posted on Apr 06, 2019
Have a poulan wild thing and the oil bar compartment has gas in it
I would drain the oil and gas or whatever is in it. I would also drain the 2 cycle mix from the gas tank and start with a fresh gas and oil mix and fresh bar oil. The mix for the Poulan Wildthing is a 40:1 mix.
You are definitely going to smell gas when using any chain saw.
Oct 28, 2014 | Poulan 18" Wild Thing Chainsaw
What goes in a kdx 80 gear oil or 2 stroke oil
Engine oil goes in the gearbox/transmission. Two stroke oil (also know as pre-mix) is mixed with the gas and oil in a separate gas can (to thoroughly mix the pre-mix and gasoline) and then the mix is poured into the fuel tank.
Jan 15, 2013 | 1998 kawasaki KDX 200
Do I mix the oil and gas together and pour it in the gas tank or do I pour the gas in the tank and the waverunner mix's the oil and gas together?
Mix the oil and gas together first.
Or you can add some gas into tank, then add some oil, then add more gas, then bit more oil ... so oil-gas mixture is uniform.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 24, 2012 | Boating
What kind of gas
Regular unleaded gas mixed with 2 cycle oil. (You need to check your model for mixture ratio but 30:1 (thirty parts gas to one part oil mix) is usually a good place to start) You can find mixing instructions on the back of the 2 cycle oil container
Dec 08, 2010 | Garden
I have a techumseh snow blower 5.5 engine. I need to know what type of fuel it needs. It says on the outside something about a 50:1 oil gas mix and lists some types of oils. Where can I get these oils,...
go to your hardware store and ask for some 2 cycle 50:1 oil, mix that with a gallon of gas and you're good to go. Before you mix, make sure that you read the oil container for it's recommendations! You can purchase a small container of oil that is all measured for 1 gallon of gas
Feb 10, 2010 | Garden
My B&S Yard Machine shoots out white smoke it also leaks out oil and gas mixed
If this is a 4 cycle mower (seperate places for gas and oil) and you are using a oil and gas mix as I am reading from your post that is your problem. When you use a gas&oil mix in a 4 cycle you get smoke and if fouls your spark plug. Also be more specific where the oil and gas mixed is leaking from. I SUGGEST THAT YOU DRAIN OUT THE GAS&OIL MIX AND CLEAN THE SPARK PLUG OR REPLACE AND FILL WITH STRAIGHT GAS AND SEE HOW IT RUNS.
Good luck
roundo4
Sep 03, 2009 | Mtd 22" Yard Machine Push Mower
I guess he needs to know what kind of oil he needs also
you shouldn't need to mix oil with gas on a four cycle engine. this is for two strokes.
Aug 23, 2009 | Garden
11A-418A729 - straight gasoline or gas/oil mix
If it has an oil stick, it is sraight gas. No oil stick to check oil then, gas/oil mix needed.
Mike
Jul 10, 2009 | Mtd 22" Yard Machine Push Mower
I dont have the manual and Im not sure what ype of oil I should put on this chain saw. On the left The nob sais oil (which kind?) and on the right side it sais oil/gas mix (which kind?) what do i put on...
The Left knob needs chain oil. Available in most hardware stores. The right is gas mixed with 2 stroke motor oil. Usually a 50:1 mix. Ie. 50 parts gas to 1 part oil. 2 stroke oil comes with a built in measuring tool and directions printed on the bottle.
Jun 03, 2009 | Garden
Does this model take a gas oil mix?
yes it does require a mix. go to any lawn and garden store and get the small bottle of oil that u mix with one gallon of gasoline.
Apr 15, 2009 | Garden
Stihl Ts 510 760  Cut Off Saw Repair Manual Logo
193 people viewed this question
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
