Question about Sierra Entertainment The Legend of Spyro: Dawn of the Dragon
How to defeat malfore
I am on the part were you defeat malfore and he is in the purple ball and i do not know how to get him.
Posted by lamar0522 on
Anonymous
    Problem Solver:
  • 9 Answers
Okay so you are going to fight him three times. My first suggestion is to get unlimted life which is really easy. While playing hold down the L1 button and press: right, right, down, down, left. This will give you a little advantage but not much. You should also make certain that Spyro has on the Dark armor as this is the only thing that will really do damage. Once you start fighting, fly close to Malfore and use Cynder's fury breath. this is done with the directional pad, pressing any direction twice. Second fight, do the same but be sure to dodge the ice. Third fight: Repeat until dead.
Hope the cheats help. Let me know.
Posted on Sep 12, 2009
Want to know how can I connect my tv STL -49E360 with my -4012USB player using the cable with the input of a HDMI. Se photo with cable. It tells me that there is no signal.Please help
Hard to see from here but I've never known an HDMI cable to end with RCA leads. It just defeats the purpose. So that connection that looks like an HDMI most probably is a USB connection. Hard to see from that distance but sure I'm around the ball park on this one!
May 13, 2015 | Miscellaneous
Do exercise balls come in different colors?
Sure, youhave the option to choose from a variety of colors (black, blue, green, purple,pink, etc.). There is not fixed color for an exercise ball.
Aug 06, 2012 | Exercise & Fitness
Dyson Animal, purple ball, no suction upright
you might be missing a blockage in the hose from the brushes to the dust collector Take apart the hoses and check
Jul 28, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Stuck on puzzle 94 (Get the ball out) 4 Can anyone help. Game Nintendo DS Professor Layton and the Curious Village
094 Get the Ball Out! 4
1. If you're persistent in your efforts, you'll eventually get the ball to
the hole, but there are tricks to streamline the process.
The large block in the puzzle is relatively limited in range of
movement, so you're going to have to do more work with the smaller and
more maneuverable blocks. If you focus on them and plan out a route,
things should go smoothly.
2. If you move the green block on the right down, you can fill the space
you create with a purple block from the right. If you can pull that off,
you'll be able to move the blue block in the upper left, which will
allow you to move the red ball out of its slot.
It may seem complicated, but give it a try.
3. There is no set solution to this problem.
Here's one way to start out. Move the lower-left purple blocks, then
slide the lower blue block to the left.
Next, drop the green block on the right down.
The rest is up to you.
However, I have found the following sequence if you can follow it to get it done in 21 moves:
Purple block = P
Yellow block = Y
Green block = G
Red ball = R
(l)eft (r)ight (u)p (d)own
P[d],P[l],B[l],G[dd],P[dd],P[rd],B[rr],R[dr],G[uu,Y[l],P[rd],
B[d],R[rru],B[ul],R[ddl],P[uuu],R[rd],P[u],R[l],G[uuu],R[rdd] = 21 moves
Thanks and please take a moment to rate as fixya.
Feb 23, 2009 | Nintendo Professor Layton & the Curious...
Where is puzzle 120
http://www.wikicheats.com/index.php/Professor_Layton_and_the_Curious_Village_(DS)/Walkthrough#Puzzle_No._078
Go here for all puzzle walkthroughs
Puzzle No. 120 Tap the open manhole above from the Sewers below.
Get the Ball Out! 3: Slide the bottom-right blue block over to the right and drop that lower purple block in the slot with the hole. Now, drop the big yellow block down. Drop the top purple block down one and then reposition the top two blue blocks so they are touching end-to-end directly under the red ball. Raise the left green and the big yellow block up into the center. Slide the bottom-right-most blue block all the way to the left. Drop and slide the other right-hand-side blue block as far left as it can go now. Drop the green block on the right down and into the right-hand nook. Slide one of the top blue blocks to the far right along with the yellow block and the right-hand blue block on the bottom. Drop the red ball all the way down to the bottom row. Move the left-hand green block up into the ball's starting slot and slide the yellow block all the way to the left. Move the bottom-right blue block up and the small purple one that blocks the hole. Now simply put the red ball into the hole.
Jan 04, 2009 | Nintendo Professor Layton & the Curious...
How do you defeat Vilgax in Ben 10 Protector of Earth
start hiting vilgax then when he powers up hit the two mechins on the right and the left quick. Then tern into wild vine and swing on wild vines spike ball then swing close to vilgax and hit him do it 6 or5 times
Dec 30, 2008 | Video Game Consoles & Games
Cheats for DRAGGONBALL Z BUDOKAI TENKAICHI 3
the only cheats for this game, are unlockable Charactors.
Android 8 - Defeat "Affectionate Android"
Arale - Defeat "Dream Match: Goku vs. Arale"
Babidi - Defeat "Farewell to the Proud Warrior"
Cyborg Tao - Defeat the second level of the Otherworld Tournament
Devilman - Defeat "Unexpected Help"
Dr. Wheelo - Defeat "Strongest in the World"
Fasha - Defeat the third level of the Yamcha Game
General Blue - Defeat "Penguin Village"
Goku GT - Defeat "Immortal Monster"
King Cold - Defeat the third level of the Cell Game
King Piccolo - Defeat "Goku Strikes Back"
King Vegeta - Defeat "Galaxy Battle"
Nail - Defeat "Super Saiyan"
Nam - Defeat "Ceiling vs. Ground"
Nuova Shenron - Defeat "Solar Warrior"
Pilaf Machine - Defeat the second level of the World Martial Arts Tournament
Spopovich - Defeat the third level of the World Tournament
Tambourine - Defeat "Goku Strikes Back"
Hope This helps Mike @ Compurepair.
Feb 23, 2008 | Nintendo Wii Console
Sierra Entertainment The Legend of Spyro: Dawn of the Dragon Logo
170 people viewed this question
Top Sierra Entertainment Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Tom Chichester
Are you a Sierra Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
