The microwave heats fine, but the turntable no longer turns.
Test the motor under the turntable carousel, if the motor is fine, check contacts to control boars, and eventually replace the control assembly (or board alone ) if you find a problem in there.
Remove bottom panel,< screws along front and tips down > the turntable motor is in the middle. Unplug motor and use multi-meter< insert probes into plug end > run short cycle with something inside of unit," glass of water ", if you have voltage here then the motor is bad and needs replaced. If not then mother board most likely problem.
