Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
SOURCE: dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches. Normally the drain valves are plastic with a Male hosebib attached. Attach a garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve. If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level. Replace the P/T valve and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads. You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
Posted on Jan 31, 2009
Sep 23, 2014 | Water Heaters
Jan 10, 2013 | GE 50 gal. Heat Pump Electric Water Heater
Feb 05, 2011 | Rheem 36" Water Heater Thermocouple Kit
Aug 02, 2010 | General Electric GE SmartWater Household...
Mar 26, 2010 | General Electric GE SmartWater Household...
Jan 08, 2010 | General Electric GE SmartWater Household...
Dec 17, 2009 | General Electric GE SmartWater Household...
Dec 14, 2009 | General Electric GE SmartWater Household...
Jun 25, 2009 | Water Heaters
251 people viewed this question
