If the switch is broken, you might find a repairer to fix it. But dont try any other way because of danger of shock. The kettle are very cheap these days , buy a new one.
The motor in the top of the machine should rotate the gear sticking out of the top of the cabinet when you turn the switch on. This gear should connect with a gear on the top of the shaft that sticks out of the kettle when the kettle is in the correct upright position and turning the stir rod.
Make sure the kettle is installed correctly, and the switch is in the on position. If the motor is not turning with the switch on, it is broken and should be returned to store if possible. There are no repair parts for this brand popper, and they cannot be repaired.
The instructions say make sure kettle motor is plugged in. Turn unit ON with switch on crown of machine. Allow unit to run for 3-5 minutes to heat up kettle. Turn unit off. Add 2 teaspoons of your favorite popcorn cooking oil to the kettle. Then add 1/4 cup of popcorn kernels to the kettle. Turn the unit on and close the door. When popping sound slows down turn the unit OFF. Flip the kettle over with the crank handle to empty the kettle. Repeat process until desired amount of popcorn has been popped.
Your electric kettle in drawing more current than your wall outlet's are made for. Not being able to read your current draw on your GE kettle I would guess you have a bad GE kettle and it needs to be returned to where you bought it.
this is more likley to be the switch its just a bimetallic type,when it gets hot steem on it it flicks the switch to turn the kettle off try giving it a realy good clean up inside around the switch it may just be lime scale blocking the vent hole
however normaly when the switch playes up its a new kettle
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
