Won't spin I have a kenmore 80 series top load wash machine. It no longer wants to spin. I was told it went off balance and when lid was closed again it made a humming noise, twice, and decided to go on strike. I'm somewhat handy but have no clue about appliances. What should I look for?
Posted by badshocks01 on
Anonymous
  • 30 Answers
The main motor bearings have seized up. The cure is a replacement motor or a new machine. Unless you can do it yourself it will be cheaper to buy a new machine as a new motor costs around $250.
Posted on Apr 26, 2009
My Kenmore 26442502 top load washer will not kick into the spin cycle after it agitates. Just kinda humms. As I open the lid while it should be spinnning, everything stops, like it should. Once I close the...
Hello Dbriner,
It would appear that the lid switch is defective and is in need of replacement. I included a video showing basically how to replace it (It is a series 80 machine but that is minor).The steps are the same.
Your part can be found here for $29.65 +Shipping
Good Luck!
Rich Lilja Kenmore Washing Machine Lid Switch Assembly WP8318084
May 20, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
My model 80 top load kenmore washes but won't spin.
INSPECT LID SWITCH IT S WERE THE LID CLOSES SHOULD MAKE A CLICKING NOISE IF NOT IT NEEDS TO BE REPLACED
Jan 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer dead
ck to see if you here a lid switch click when lid is slowly closed if not suspect lid switch may be on right sidew of opening or under left rear of lid at hinge also ck for loose lid hinge screws left side first
Sep 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer will not spin
KENMORE 80 SERIES 110.92582110 - NOT SPINNING. I REPLACED THE TRANI, CLUTCH, COUPLER BUT I FORGOT TO PUT BACK IN THE AGITATOR WASHER. IT STILL WON'T SPIN SO WHAT NEXT
Jun 12, 2008 | Kenmore 23822 Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
