SOURCE: My JL audio 1000/1 amp does not work
Best bet is to send it back to JL, they do not sell the PCB with all of the components loaded on it. Most likely the transistors in the power supply have fried. Open it up and see if you can find any physical damage. Google the part numbers of the bad parts, and you should be able to fix it relatively easily. www.digikey.com is a great place for parts. Read this for more testing procedure: http://www.bcae1.com/ampfail.htm The whole site is wonderful, really.
SOURCE: JL Audio 1000/1 power LED is On But no Sound
my amp did same shit, its the rca cabbles, check them out at the back of the head unit. the input jack is probably bad on the head unit
SOURCE: help
JL amps are somewhat sensitive to low voltage. Everything has to be perfect in the power supply feeding the amp. I'll assume that you have large enough wire. Check the owner's manual on the JL site. They likely recommend 4g or larger. You need to measure the voltage across the B+ and ground terminals of the amp. If it's dropping below ~11v when you turn the volume up, you need to determine why. Make the same measurements at the battery terminals. If there is significantly less voltage drop there when the volume is increased, check all of the points in the circuit where there could be a bad connection. Look for corrosion, over-heated connection on fuses or at the battery and make sure the fuse is in good physical condition. Some types tend to overheat and melt. If everything looks OK, begin measuring the voltage at each point where there is any sort of connector. If for example, you get a significant difference in the voltage on each side of the fuse, the fuse, the holder or the connections to the holder may be defective.
SOURCE: jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
SOURCE: Green power light on JL Audio 500/1 but no output
Its the power transistors that would be affected by low voltage. It delivered till it finally gave up 'cos the output wattage to be generated at low voltage means more current flowing through the equipment. This high current will adversely affect all small solenoid valves & transistors and IC's. Even failure of one section of any IC is rarely detectable with the naked eye. It has to be thoroughly checked with a multi-meter to assess the damage correctly......sodeep
