Question about Kenneth Cole RK5034 REACTION
Kenneth cole reaction rk5053 rk5044 - Kenneth Cole RK5034 REACTION
5 Related Answers
Anonymous
SOURCE: manual
did you find one? looking for one myself
Posted on Mar 06, 2008
Anonymous
  • 4 Answers
SOURCE: DAMAGED CRYSTAL
Send a photo so I can see if the crystal needs to be custom cut or whether a generic will work. [email protected] Thanks.
Sarvadrk
Posted on Jun 19, 2008
Anonymous
SOURCE: leather watch band
I might have the solution. Is it a rectangular watch with a leather strap? It sounds weird, but I have a watch with no brand name on it (bought yesterday from K-Mart at $9.99) with the model #A126-06. The package insert said "Advance Watch Group." I googled them, and they manufacture watches for Kenneth Cole, Tommy Bahama and a bunch of other designers.
I was really surprised because K-Mart is the last place I'd buy a watch, except that it looked like my broken Raymond Weil tank watch.
I suggest you go to K-Mart and see if you find a watch that looks like yours.
The back of this watch is marked as follows:
V377
Stainless Steel Caseback
2035 Movement
Base Metal
Bezel
20279knx
A126-06
Posted on Aug 10, 2008
Anonymous
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: wristband too big
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 13, 2009
How do i set time for Kenneth Cole Reaction New York Digital Chronograph Men's Watch # KC1494
How do i set time for Kenneth Cole Reaction New York Digital Chronograph Men's Watch # KC1170
Jan 09, 2015 | Kenneth Cole Watches
Hi!!!!!!!!!!! not able to set the date and day feature ( model UL1134) . is it adjustable or just for show on the face of the watch ????????????
Sounds like you have been struggling with your watch!
If you go to http://www.genevawatchgroup.com/ and select "customer service" from the menu on the right and scroll doen that page and you will see Kenneth Cole Reaction watch instructions.
I could not find the model number you give, as all their models start with "RK" but there are "reaction" models with large displays included in the list, so you should be able to find the one that matches yours.
Sep 16, 2010 | Kenneth Cole RK5044 Reaction Watch
Kenneth cole reaction KC1408 changing battery problem
You have to take the back off. If it has about 6 slots around the back, then it screws off. If it's flat, then you can pry it open. If you pry it open, it,s very difficult to get it back on all the way. You may have to get some tools, or go to a repair shop.
Mar 02, 2009 | Kenneth Cole Watches
Cracked glass on the dial
I have no idea how the things work in India, but any Kenneth Cole dealer shop must be able to sort your problem ( at least it is worldwide experience ). So, visit your nearest Kenneth Cole store and ask for help.
Do not forget to rate, please.
Feb 06, 2009 | Kenneth Cole RK5034 REACTION
Kenneth cole KC1426 straps
Find your nearest Kenneth Cole retailer and ask for assistance.Visit www.kennethcole.com for locating nearest store.
Dec 16, 2008 | Kenneth Cole RK5044 Reaction Watch
DAMAGED CRYSTAL
Sarvadrk
Jun 19, 2008 | Kenneth Cole Reaction - REACTION SILVER &...
Kenneth cole watches
Link
Good day,
You might want to try above link for your need of a band replacement.
Kindly refer to above link.
Good Bless
May 09, 2008 | Kenneth Cole RK5044 Reaction Watch
Kenneth Cole RK5034 REACTION Logo
91 people viewed this question
Top Kenneth Cole Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
