Model whdsr209 washer will not rinse cycle stops and hums
Check the setting of the water temp for the rinse cycle. If one of your water supply valves is closed (HOT/COLD) the tub cannot fill with the proper water temp selected. The hum noise you are reporting is associated with the fill solenoid valve located in back of the machine.
Also, I have found the problem to be the screen located in the fill valve clogged with rust and water deposites. Disconnect both water lines and verify the water supply is not restricted.
Hope this helps..
If not, a more thural description of the problem may reveal more clues to assist in troubleshooting.
Thanks and good luck...
