Passenger rear door stuck open, door prop will not let release. This is a1987 mercedes 300d turbo sedan.
In the U.S. the type,
adjustments, and illumination factors of all automobile lighting devices
are regulated by the Federal Motor Vehicle Safety Standard 108. The
headlights must function and be adjusted correctly. Your high beams must
disperse their beams straight forward and low beams down and to the
right while safely providing illumination without too much or too little
glare. It is wise to check the headlight adjustment on your Mercedes at
least every year. Doing it yourself will save you time and money. It
will also make driving safer for you and others you may meet on the road
at night. All it takes is time, some basic tools and a little patience.
Other People Are Reading
Thanks lastech I got the door panel off and removed the door brake, with some prying and penetrate oil was able to free the old one up. thanks prry tech
rear deck lid is stuck, Button turns correctly and also pushes in but will not release deck lid
